Old 10-09-2015, 04:05 PM   #1
morethanstock66
morethanstock66's Avatar
Exclamation Wiper Switch Grounding Issue
So, I have an OE style two speed wiper switch with the washer button. I know that the switch grounds through the original metal dash. However, I have a Classic Dash panel that is not metal. I was curious if anyone else with the same set up has used an OE style wiper switch. If so, how did they ground it? Or, is there a switch out there with a grounding post, because that would be easier
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
Old 10-09-2015, 06:59 PM   #2
ray_mcavoy
Re: Wiper Switch Grounding Issue
I'm not aware of any OE style wiper switches that have a ground terminal. At least not until the later model switches, but by then they had mostly all changed to a slide side-to-side type switch instead of a rotary knob.
Fabricating a grounding plate that can be sandwiched in between the switch and the back side of the dash panel should be a fairly easy fix. Just drill an appropriate sized hole in a small piece of thin sheet metal and attach a ground wire to it.
ray_mcavoy is offline   Reply With Quote
Old 10-21-2015, 11:40 AM   #3
morethanstock66
Sorry for the delay, While great in theory, it does not work in practice. I drilled and soldered a wire to a washer and tried to screw the OE style switch to the aftermarket dash bezel-no dice. Unfortunately the threads on the switch are just long enough to screw in normally, not so with the washer.
Old 10-21-2015, 04:53 PM   #4
forestb
forestb's Avatar
I would find the thinnest peace of sheet mettle I can find and make my own washer and if that does not work you can cut off the insulation on the ground wire for the same length as the circumference on the switch and wrap the wire around it. If the second sounds unsafe don't do it. It is just a thought.
forestb is offline   Reply With Quote
Old 10-21-2015, 05:54 PM   #5
morethanstock66
Good idea, I may give the sheet metal idea a go. It is always the little things like this that make me want to pull my hair out. It seems so simple until you try and fix it
Old 10-22-2015, 10:46 AM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I would get a thin sheet of brass (get at a hobby store) and make a "washer" from that. You can get paper thin sheets and brass is very conductive and easy to solder on.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-22-2015, 11:53 AM   #7
morethanstock66
I will try this out, I never thought of hobby stores, thanks for the info!
wiper switch
Thread Tools
Display Modes
