10-12-2015, 02:29 AM | #1 |
Gas tank under bed
I am looking to relocate my gas take to under the bed of my stepside. Is there any tank that will fit and have the sending unit work with the original gauge?
Nik
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
10-12-2015, 06:27 AM | #2 | |
Re: Gas tank under bed
Have you done a search on our great forum? Sam Last edited by luvbowties; 10-12-2015 at 06:31 AM. Reason: grammar |
10-12-2015, 10:55 AM | #3 |
I'm looking at this too for next year's 62 4x4 build.
Where does the filler neck come out on a step-side with an under-bed tank conversion? -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
10-12-2015, 11:45 AM | #4 |
boyd welding tanks are excellent under bed tanks that fit great, they have option of 3 different ohm sending units and offer In tank fuel pumps or just regular for carb options. Very reasonable pricing and it's an aluminum tank, 0-30ohm is what works for your stock guage, 0-90 is for an autometer style newer style gauge which is most common, the other option is a 0-220 or so ohm for straight digital. Hope this helps in your search. Best option in my opinion do it once and never worry about it again.
10-12-2015, 04:28 PM | #5 |
You probably already know this but the rear frame on a 62 is wider than a 63-66 so if you buy a tank that says it will fit a 63-66 it will fit in your 62 but you will need to need to figure out a way to mount it between wider frame rails.
10-12-2015, 04:49 PM | #6 |
Thanks forestb.
Getting the tank mounted won't be too bad--I'm a decent enough fabricator that I can make things fit neat and clean. My concern is with where the filler neck goes. -Brad
10-12-2015, 04:56 PM | #7 |
I made a trap door in the bed. But I have seen people use a camaro tank where the filler neck faces the back of the truck and then install a flip down license plate to cover the filler neck. That is what I wold do if I had to do it all over again.
10-12-2015, 05:01 PM | #8 |
Classic parts of America makes a nice kit. Considering it myself. Part # 23-928A or B. (A) for top fill and (B) for side fill. Here's the side fill.
http://www.classicparts.com/1963-66-.../#.VhwfaflVhBc
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
10-12-2015, 06:58 PM | #9 |
www.tanksinc.com . The unfortunate thing is it is only 16 gals.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
Thread Tools | |
Display Modes | |
