Old 09-14-2003, 01:06 AM   #1
bigger=better
bigger=better's Avatar
Question A/C retrofit
Anybody know if the rear A/C unit from a new burb would fit in the spare tire well of 67-72 series?
'68 GMC Sub 4X4 new project
'69 Pontiac GTO 20 year project
Never hold your farts in. They travel up your spine, into your brain, and that's where you get sh*tty ideas from.
bigger=better is offline   Reply With Quote
Old 07-28-2010, 04:43 PM   #2
Crownliner
Crownliner's Avatar
Re: A/C retrofit
I want to find out about this as well!!!!!!!!!!!!! I would love to add AC to the spare tire well!!!!!
Crownliner is offline   Reply With Quote
Old 07-29-2010, 04:16 PM   #3
Crownliner
Crownliner's Avatar
Re: A/C retrofit
SERIOUSLY????????? HAS NO ONE THOUGHT OF ADDING AN AC UNIT TO THE SPARE TIRE WHEEL WELL IN THEIR SUBURBAN? It was the first thing I thought of since my spare tire is on the roof.
Old 07-29-2010, 10:03 PM   #4
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: A/C retrofit
I've thought about it but my burb is currently in a thinking phase.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 07-30-2010, 06:13 AM   #5
draggingframe01
Re: A/C retrofit
I'de like to see a thread on an install
draggingframe01 is offline   Reply With Quote
Old 07-31-2010, 06:41 PM   #6
kev2809
low n' slo
kev2809's Avatar
Re: A/C retrofit
me too. ill have to face the a/c issue one day, just not on my list for now. i always wondered about the setup from a 73-87 burb...
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 07-31-2010, 08:51 PM   #7
project 67 sub
project 67 sub's Avatar
Re: A/C retrofit
no pics of it but i have one currently mounted to the roof inside of my burb.its not hooked up though. i had to extend the front monting brackets to reach the cross brace in the roof
edit: the cover also does not fit perfect in our burbs and will need some mods to make it completely cover the unit at the rear, as there is a open gap between it and the inner body
project 67 sub is offline   Reply With Quote
Old 08-02-2010, 12:29 PM   #8
kev2809
low n' slo
kev2809's Avatar
Re: A/C retrofit
what year is your setup from?
-_--_--_ _________
Old 08-02-2010, 04:19 PM   #9
Scott Johnson
Junior Member
Scott Johnson's Avatar
Re: A/C retrofit
Check out this thread I have pics of a 90 model unit I have mounted in mine. It is not hooked up yet, but it will not be a problem to do so. I think it fits in pretty nicely.
http://67-72chevytrucks.com/vboard/s...d.php?t=411412
71 C10 Step Daily Driver
72 K10 Suburban Work in Progress
www.louisianaclassictruckclub.com
Scott Johnson is offline   Reply With Quote
Old 08-02-2010, 04:29 PM   #10
kev2809
low n' slo
kev2809's Avatar
Re: A/C retrofit
thats actually not half bad. i would rather have in the middle of the roof as opposed to the rear, do you think it could be mounted like that and run the lines off to the side?
also, how did you setup the front and under hood stuff?
-_--_--_ _________
Old 08-02-2010, 11:38 PM   #11
Scott Johnson
Junior Member
Re: A/C retrofit
You would have to get longer lines to run around your windows unless you have a panel. I chose to put mine in the back because it looks like it was made to fit there. I have my truck off the frame right now with nothing hooked up, but I have all the hoses and everything. The lines just tee off out of the evaporater core and run along the frame rails to the back. I am using the motor and all the accesories (serpentine) out of the 90 model. I plan to fit the evaporater core unit and blower motor from the 90 to my firewall, that way I will have a more current a/c system that doesn`t use the poa valve. I think the newer model units fitted in the spare tire well is a great idea, they probably are plumbed similar to my set up, I just had access to a complete 90 model truck that I could pull everything out of. I plan to run my hoses through the back part of the spare tire well and use the rest of the area as a small compartment.
Old 08-03-2010, 04:02 PM   #12
project 67 sub
Re: A/C retrofit
its from an 86ish
edit: it looks just like Scott Johnson's but blue
Old 08-07-2010, 12:38 AM   #13
chris mc bride
chris mc bride's Avatar
Re: A/C retrofit
Just psoted a thread about the same thing except,Im wanting to add rear a/c from a astro van amd mount it to roof just as is now. Wondering what effect it would have on rest of sytem and if I need more flow to carry the extra cooling coil.
chris mc bride is offline   Reply With Quote
Thread Tools
Display Modes
