09-14-2003, 09:18 AM | #1 |
Barn doors to lift gate.
Our own board.....COOL! Anyone switch from barn doors to a tail/lift gate set up? Is this an easy swap or a nightmare? Thanks!
Bob Chayer 71 3/4 ton 4X4 Suburban |
09-14-2003, 12:21 PM | #2 |
Mike
I think it is easy.The holes and slots are all ready there for the bolts and hinges.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
09-14-2003, 02:47 PM | #3 |
Do you have any pics showing how the tail gate and lift gate mount? That way I can check my burb to see if I have the mounting points and get an idea how much work would be involved. Thanks!
09-14-2003, 04:15 PM | #4 |
Mike
I don't have pics but,open your doors.Along the top edge of the opening you should see 2 rubber plugs a bout 2"long.Also along the bottom there should be the same.
09-14-2003, 10:09 PM | #5 |
doors
I was thinking about going from lift gate to barn doors. But got to looking and have some questions about the catchs in the middle for the barn doors. How does a person attach the top catch?
The Joker |
09-15-2003, 06:56 AM | #6 |
Smokekiki, thanks for the info I'll check it out.
Joker, I will check on my burb today and see how it works.
09-15-2003, 12:02 PM | #7 |
My recollection is that the base (behind the rear mat or carpet hold-down plate) is different between the 2 styles. My dad wanted to switch from tailgate to barn doors on his '74 (similar design), but found he couldn't do it without finding a donor for the baseplate and having it welded in. Needless to say, he still has a tailgate!
'72 Chevy Suburban Custom Deluxe 10, 402/TH400 |
09-17-2003, 12:02 AM | #8 |
you can go from a tailgate to barn doors with little modification.You'll spend a lot of time goin' the other way...
you never have too many suburbans.... |
09-17-2003, 12:03 AM | #9 |
tailgate pic
09-26-2003, 10:48 PM | #10 |
I HAVE A 68 CHEVY PANEL TRUCK (THAT I HAVEN'T RESTORED YET) & I JUST BOUGHT A 72 GMC BURB OFF EBAY, THAT I HAVEN'T PICKED UP YET (IT REQUIRES A ROADTRIP WITCH I WILL EMBARK ON MONDAY) SO I DON'T REALLY KNOW A WHOLE LOT ABOUT THESE TRUCKS, ALTHOUGH I'VE BEEN RESTORING 67-72 CHEVY PICKUPS & BLAZERS FOR 18 YEARS. I WORKED AS A LAYOUT INSPECTOR FOR GM TRUCK & BUS IN FLINT MICH. DURING THE 80s, WHERE WE BUILT SUBURBANS, BLAZERS & PICKUPS. AT THIS TIME THEY USED ENTIRELY DIFFERENT PLATFORMS FOR BARN DOOR & TAILGATE/LIFTGATE MODELS & THEY WERE IN NO WAY INTERCHANGABLE. BUT THAT WAS THE EIGHTIES SUBURBANS.... MAYBE THEY WERE INTERCHANGABLE BACK IN THE LATE 60s & EALY 70s.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
09-27-2003, 08:49 AM | #11 |
Thanks for the info. I finally found the time to check it out and it is completly different. Looks like i'll stick with what I have.
12-06-2010, 01:56 AM | #12 |
"something witty here"
Re: Barn doors to lift gate.
Did you ever do the swap? I was wondering how hard it was to swap from barn to a lift gate....
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
12-06-2010, 02:09 AM | #13 |
BlahBlahBlah
Looks like the last time he was on line here was August of 05, he may not answer you =)
12-06-2010, 02:39 AM | #14 |
I didnt really think to check that, I just didnt want to start a new thread and thought someone else might chime in...
12-06-2010, 07:20 PM | #15 |
Wow! Brought back from the dead after seven years. I think thats the longest ressurection I have seen up to now.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends. '72 blazer 2wd build 67-72 Factory Big Block Registry |
12-06-2010, 08:35 PM | #16 |
I found frizzle fry and rokcrin both had done the mod that I will do in their tahoe builds.....
ps most other forums you get reamed out for starting a new thread when there is a thread already out there on that topic. And I didnt think to see if the OP had been on lately....
12-06-2010, 08:43 PM | #17 |
BlahBlahBlah
We dont ream around here, but you may get a little ribbin lol
12-06-2010, 08:50 PM | #18 |
Oh I dont mind that at all, but one site I tried for gsxr's was insane and ever since Ive been leery lol
12-07-2010, 07:46 AM | #19 |
The easyest way to change from barn doors to lift gat is to change out he lower door sill sheet metal with on from a tail gate truck. I have all of the parts and just gettting started with this project.
Wade "DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project 2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's 79 RS Camaro |
12-07-2010, 11:49 AM | #20 |
Thats what I was going to do, I was just going to get a vendor thats parting a sub here to cut out that piece needed, but now I think Im going a different route...
12-07-2010, 12:37 PM | #21 |
I wouldn't worry about getting reamed. If someone dosn't want to read the thread they don't have to click on it. I don't worry about my threads bieng up to anyone elses standards and you shouldnt have to either. I just thought it was crazy how old the thread was. I usually only notice that it is an old thread because there are a bunch of names/avatars that I havent seen before or in a while.
12-08-2010, 12:50 AM | #22 |
If you do hidden hinges you shouldn't need a donor liftgate header panel since you will be creating your own hinge mount points.
12-08-2010, 02:18 AM | #23 |
Its been awhile since Ive read your tahoe thread, I had just read rokcrin's and he gave credit to you for the design of the hinges so I assumed you had done the same with your build, but I really wasnt sure. Ill have to find when you did that mod among the 50 some odd pages on that build lol. I plan on doing the liftgate/barn door idea if I can. Although I do really like the way you did a one piece!!!
Thread Tools | |
Display Modes | |
