Old 10-19-2015, 09:53 AM   #1
flipper58
flipper58's Avatar
Need help--71 vapor canister location
Can anyone share a photo of an installed stock vapor canister on a 71 C10? 307 2 bbl. I've got mine all cleaned up and ready to go back on and didn't take a photo before removal. Any help is appreciated.
Thanks,
Phil
flipper58 is offline   Reply With Quote
Old 10-19-2015, 10:27 AM   #2
Davidf
Re: Need help--71 vapor canister location
The canister on my '71 was removed and stored in the bed side compartment when I purchased my truck. But, I believe the correct location is on the right fender just behind the core support. Down low between battery and fender.
Davidf is offline   Reply With Quote
Old 10-19-2015, 10:37 AM   #3
dfwright
dfwright's Avatar
Mine is a 72 with a 350. I don't know if they are exactly the same or not, but perhaps these might help
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 10-19-2015, 10:42 AM   #4
flipper58
flipper58's Avatar
Just what I needed, gents. Thanks very much.
Phil
Old 10-19-2015, 02:59 PM   #5
WarMonger
WarMonger's Avatar
Phil, I just pulled mine off my 72 blazer yesterday (can and mount) it you are looking for one?
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 10-19-2015, 07:12 PM   #6
WarMonger
WarMonger's Avatar
Mine does not make any noise when it shakes
Old 10-19-2015, 07:43 PM   #7
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I've had some recent experience with canisters of late. You do know if the charcoal isn't loose then it's no longer working properly? At any rate, mine was bad and not worth saving.
At any rate:
Purchase #1, early 71 part #. The canister is beautiful. I noticed the internal element, was pretty dirty, as the filter you can access. No problem, at least one filter can be replaced without opening it. As I'm polishing it (again) I see charcoal coming out. Big hole in the inner element. Charcoal looked fresh. Either I broke through the element by shaking it or possibly, they damaged it trying to replace the charcoal without cutting it open. Still, it was basically free. I'll cut the my old one open for practice, then cut the newer one and restore. I bought what I think will work for that inner element, however any suggestions for what this part is supposed to be is appreciated.
Purchase #2: GM replacement part for 71-72. Pending receipt, but by the looks of the canister and filter, it was never used. If true, then it was a sweet deal.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 10-20-2015, 08:02 AM   #8
flipper58
flipper58's Avatar
Thanks Warmonger and 71CSB. Mine is in fine shape and just needed some external cleanup and a re-paint.
Phil
Old 03-19-2016, 04:56 PM   #9
Hack71
Hack71's Avatar
Smile Re: Need help--71 vapor canister location
Love this site, thanks for every ones input, I took my canister off months ago thought I had enough pictures to put the truck back together.... but I was wrong!!
http://67-72chevytrucks.com/vboard/s...d.php?t=693490Cheyenne, AKA "Spare Change" Hack71 Build
Hack71 is offline   Reply With Quote
Old 03-19-2016, 06:19 PM   #10
In The Ten Ring
I have this to look forward to in the coming weeks. I took most of my front end off to repaint the parts and that included the charcoal canister. My father unhooked it and I'll have to figure out how to make it work again. At least now the bracket is rust free. I'll try and get a new canister.
In The Ten Ring is offline   Reply With Quote
Old 03-29-2016, 11:54 PM   #11
GTCS
GTCS's Avatar
Newbie question - Summit Racing sells what is probably a generic canister.
http://www.summitracing.com/parts/sm...olet/year/1973
If my '72 Cheyene already has a canister is it usable forever or do they wear out or get plugged. Someone cut off the hoses and I have a gas smell in the cab so I want to get the vapor system back up and running. I don't want to waste money but if they do get less efficient over time I'm OK with a generic one to use as a driver, while storing the old one. Are they all pretty much the same?
What are your thoughts?
GTCS is offline   Reply With Quote
Thread Tools
Display Modes
