What are the differences between 1/2- and 3/4-ton axles?
I'm going to start a '62 K-10 project this winter, and am wondering what the main differences are between the 1/2- and 3/4-ton front axles.
Well, rear axle too, for that matter. I'll assume the axle flanges, drums and wheels are 8-lug vs 6-lug. Are the bearings bigger? (front and rear axle) U-joints in the front axle bigger? For the front end, are the tie-rod ends and other steering linkage larger diameter? I'll also assume there's a little more leaf spring in the 3/4-ton trucks, but hauling won't be a consideration for me. Aggressive off-roading won't be either, but going back on hunting and fishing trails will definitely be on the agenda. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
![]() Join Date: Mar 2003
Re: What are the differences between 1/2- and 3/4-ton axles?
Yes to all of your comments, u-joints will be 1 step up in the rear also for the driveline
![]() Join Date: Aug 2008
1/2 ton rear is semi floating. 3/4 ton is full floater. Usually also a couple inches wider overall.
Front 1/2 and 3/4 ton dana 44s are, for similar years, the same all the way out to the knuckles. Hubs are different obviously. There are also two types of 3/4 ton spindles and hubs: a large bearing and a small bearing.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
#4 | |
Just as well... I really don't think I'm going anywhere that is going to break my 1/2-ton axles. Pastures, dirt roads, the occasional woods. And it'll almost always be empty in the box. -Brad
Unless you are hauling, or running large tires, I say really no need to step up to 3/4 ton axles.
Personally, I don't like semi floating axles. But in reality they are fine for light duty vehicles.
Thread Tools | |
Display Modes | |
