Old 11-11-2015, 09:59 AM   #1
Dans1960SWB
Rpo code?
431XE? Any clue what that is? I tried to Google it with no luck...
Dans1960SWB is offline   Reply With Quote
Old 11-11-2015, 04:15 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Rpo code?
I don't have RPO codes previous to 1963. A new system started in 63 that had a letter to indicate the group.
This link will provide all I have found so far.
http://67-72chevytrucks.com/vboard/s...d.php?t=591181
Old 11-11-2015, 05:07 PM   #3
Ennehazrad
Re: Rpo code?
I have no idea what the "XE" means, but RPO code 431 shows up in two places in the GM Heritage Archives for 60-62 Trucks: once for 1960 Trucks on page 24 of the pdf file (printed pg.23), it is described as "Custom Equipment - 10 through 80 Series".
Code 431 shows up again for 1962 Chevy Trucks on pdf pg.5 (printed pg.3), also described as "Custom Equipment" but includes a few listed items- too many to list here.
Hope this helps, here's the link to the Vehicle Information Kits for Chevy Trucks: https://www.gmheritagecenter.com/gm-...tion-kits.html
Ennehazrad is offline   Reply With Quote
Old 11-12-2015, 11:11 AM   #4
60-66
60-66's Avatar
Re: Rpo code?
To confirm what's said above , this is from the 1960 truck Data book. I'm assuming you found this code on the data tag under the dash ?
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 11-13-2015, 03:37 AM   #5
Dans1960SWB
Re: Rpo code?
Yes I did find it on the tag. It also says 235 six. The truck came with dealer installed A/C and must have been a real slug with a 235/AC....
Thread Tools
Display Modes
