Old 11-14-2015, 12:38 PM   #1
1968aj
Battery hold down ideas?
I bought a new battery. this battery does not have a large enough lip on it for the factory clamp to work. anybody fabricate their own battery securement. I just installed a new battery tray. anybody else had this problem? any ideas on making a better than factory clamp? THANKS
1968aj is offline   Reply With Quote
Old 11-14-2015, 01:33 PM   #2
bill3rail
bill3rail's Avatar
Re: Battery hold down ideas?
Look at some of the images online to get ideas...
https://www.google.com/search?q=batt...w=1252&bih=602
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 11-14-2015, 01:44 PM   #3
In The Ten Ring
Battery hold down's are pretty easy to make.
My dad has bent one end of a metal rod, threaded the other for a nut, and used a metal bar across the top of the battery with a hole on each end for the threaded rod. The bent ends hook into holes in the battery tray.
You could make something with those bungee cords, I have seen dad do that too.
Look at what you need and figure out how to get there.
In The Ten Ring is offline   Reply With Quote
Old 11-14-2015, 02:06 PM   #4
roboticjunky
I've used a cam style and a ratcheting style tie downs before to hold a battery in place.
roboticjunky is offline   Reply With Quote
Old 11-14-2015, 07:22 PM   #5
Mac's
I went years with a bungee cord on my beater truck.
Mac's is offline   Reply With Quote
Old 11-14-2015, 07:56 PM   #6
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Anyway you can return the battery and get one that works? I've never bought one that didn't.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 11-14-2015, 08:13 PM   #7
1968aj
the battery was the the only one that even came close to fitting at wal mart.yes I could wrap a bungee cord around it but I am looking for ideas that look better. may get some all thread and make one.
Old 11-14-2015, 08:40 PM   #8
bill3rail
bill3rail's Avatar
Old 11-14-2015, 10:01 PM   #9
71CHEVYSHORTBED402
IMO I wouldn't buy a Walmart brand. I used to buy cheap batteries (assuming cheap), but I had starting issues between that and the starter, and that was from Walmart. Yeah good is twice as much cash.
Tony
Old 11-14-2015, 11:00 PM   #10
1968aj
bought many batteries frpm wal mart they last as long as high dollar ones.
Old 11-14-2015, 11:04 PM   #11
71CHEVYSHORTBED402
Agreed to extent, it's all I used to buy. I used to think a battery is a battery. I could be wrong, but I could swear my starting issue was part starter, part not enough power to the starter, and the battery wasn't that old. Then I have to consider the original battery on my Tundra. I replaced it after seven years, and not because I had to. I don't think you'd see that with a cheap one.
Tony
Thread Tools
Display Modes
