Old 11-24-2015, 09:29 PM   #1
In The Ten Ring
How do I paint the outer grill?
Sorry for no pics, my computer won't download my camera pics right now.
I picked up my outer grill from the metal polisher yesterday and it is stunning. I know that the 1972 outer grill was painted satin black around the headlights, what is the best (and easiest) way to mask that area off for paint?
In The Ten Ring is offline   Reply With Quote
Old 11-24-2015, 09:33 PM   #2
Re: How do I paint the outer grill?
Masking tape
Old 11-24-2015, 09:47 PM   #3
In The Ten Ring
Masking tape? Are you sure?
I figured so but I want to be able to follow those contours.....
Old 11-24-2015, 09:57 PM   #4
72c105speed
Use thin masking tape 1/8" or 1/4" then regular to tape plastic or paper to cover larger areas!!
Need pictures of this grill!
72c105speed is offline   Reply With Quote
Old 11-24-2015, 10:21 PM   #5
kingstrider
kingstrider's Avatar
Better yet, use 3M vinyl striper's tape, it seals much better than regular masking or painter's tape. I used to use it to mask the binding on my custom guitars.
1972 Cheyenne Super swb:
http://67-72chevytrucks.com/vboard/s...d.php?t=684318
kingstrider is offline   Reply With Quote
Old 11-24-2015, 10:35 PM   #6
swamp rat
swamp rat's Avatar
Brings up a question though, if it has been polished ya better skuff the surface with some scotchbrite or fine sand paper?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-24-2015, 11:04 PM   #7
jocko
jocko's Avatar
yes and yes on the 3m striping tape - best way to make the edge you want and then mask back from that - and the scuff part. Personally, I'd mask first, scuff the area to be painted LIGHTLY with scotch brite, unmask, remask, then paint.
Old 11-25-2015, 12:28 AM   #8
Mapearso
yes you need to do that
Mapearso is offline   Reply With Quote
Old 11-25-2015, 12:31 AM   #9
I'd use 2" tape and cut the line with razor knife. Here is my GMC I redid the accent on in '01. Picture was about a month ago. The chrome was dull on the inner headlight doors so I painted them leaving the face chrome:
Yeah, I'd scuff that area before paint.
Old 11-25-2015, 12:35 AM   #10
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Good idea. Good info. here, I have to do the same. Semi-gloss huh?........Noted.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 11-25-2015, 08:53 AM   #11
I use Dupli-Color low gloss black. I'm wondering once you guys mask the edge with the striping tape how you follow that to mask beyond that?
Thread Tools
Display Modes
