Old 11-26-2015, 03:40 PM   #1
slepysal
slepysal's Avatar
Gutters
So my 1960 has no rain gutter "dimple" to allow the water to drain. I don't want to fill them.
I was thinking of drilling a small hole in a corner to help therm drain.
Dose any one have a better idea or solution?
thanks in advance
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 11-27-2015, 12:10 PM   #2
'63GENIII
'63GENIII's Avatar
Re: Gutters
Mine has a small hole that looks like it was punched. Want me to get a pic of it for you? If it were me, I'd drill it.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 11-27-2015, 12:33 PM   #3
'63GENIII
'63GENIII's Avatar
Re: Gutters
Got bored and took a pic. Kind of a weird shape hole.
Chris
'63 k15 long step
Old 11-27-2015, 12:41 PM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Gutters
my suburban and later trucks have those same holes, probably an "improvement" that gm did- maybe people were complaining about water just sitting in the gutter?
Old 11-27-2015, 12:47 PM   #5
slepysal
slepysal's Avatar
Re: Gutters
Thanks for the pics. I've seen those on later models and I agree they were added on to clear the drip rails.
Ok I ll drill a hole paint it and see what happens thanks again.
Old 11-27-2015, 12:48 PM   #6
'63GENIII
'63GENIII's Avatar
Re: Gutters
Taking the pictures just reminded me that I have to seam seal my gutters... which means getting the rust out of the gutters first. UGGHH!
Chris
'63 k15 long step
Old 11-27-2015, 01:07 PM   #7
65 C20
Re: Gutters
Was just wondering if there was just the 2 holes, 1 on each side or is there ones by the front two ?
The reason I am asking is that the PO put sealer up there and blocked off the back holes.
65 C20 is offline   Reply With Quote
Old 11-27-2015, 01:43 PM   #8
'63GENIII
'63GENIII's Avatar
Re: Gutters
I just looked again. No holes in front. The PO of mine took all of the seam sealer out so I can pretty much see all of the gutters.... and the rust! Luckily its not rot yet. Still gives me anxiety when I think about it though.
Chris
'63 k15 long step
Old 11-27-2015, 02:13 PM   #9
65 C20
Re: Gutters
Thanks 63 GENIII.
I will drill out the sealer and touch up the paint.
Old 11-27-2015, 02:21 PM   #10
jonzcustomshop
1961 crewcab
Re: Gutters
I will have to double check, but I think my 65 has holes above the rain gutter on the front post, and in the back like the ones pictured.-4 total
Old 11-27-2015, 02:27 PM   #11
scuderia
scuderia's Avatar
Re: Gutters
4 holes, two on each side front and back.... as the photos shows a little more like a slot ( i put a zip tie in mine when resealing to keep clear).
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 11-27-2015, 02:28 PM   #12
'63GENIII
'63GENIII's Avatar
Re: Gutters
I like the zip tie idea. Thats a good one!
Chris
'63 k15 long step
Thread Tools
Display Modes
