Old 12-05-2015, 11:15 PM   #1
Gregski
Post Whore
Gregski's Avatar
How Much Free Play In Drive Shaft
Hi all, I tried doing a Search on this topic before posting I swear.
I have a two piece drive shaft with a center support bearing in my 2WD 1974 short bed with a Muncie SM465 4 spd. It appears that with the truck being stock and at stock height the drive shaft was already all the way in where it comes apart. As a matter of fact it was stuck solid and I had to use a puller/separator to get it apart. I don't know why? But at this point it doesn't matter. I have lowered the truck 2" in the front and 4 inches in the rear since then. And will need to have the drive shaft shortened so my question is:
How much free play should there be in the drive shaft? The manual don't say. So in other words with the car on the ground, wheels on the pavement, if I was to unbolt the rear U joint and slide the shaft in and out how much should it slide in and how much should it slide out?
Thank you all, be gentle I am learning about this stuff.
Gregski is offline   Reply With Quote
Old 12-05-2015, 11:25 PM   #2
Gmc.guy
Gmc.guy's Avatar
Re: How Much Free Play In Drive Shaft
I have the same step, same year. There is about 3/4 inch at ride height. Mine is not lowered. I have the heavy 7 leaf pack, so it's stiff. There is Maybe 3/8 shiny spot from regular daily driving in and out travel. Hope that helps you. It may not be correct but I do not have any binding issues.
-Cody
Gmc.guy is offline   Reply With Quote
Old 12-05-2015, 11:27 PM   #3
Gmc.guy
Gmc.guy's Avatar
Did you Untread the cap on the snout of the back shaft ? My first one I hammered off not knowing it worked that way many years ago
-Cody
Old 12-06-2015, 01:42 AM   #4
Gregski
Post Whore
Gregski's Avatar
Thank you that is very detailed and helpful.
Old 12-06-2015, 01:42 AM   #5
Gregski
Post Whore
Gregski's Avatar
Yes I unthreaded it ie removed it properly.
Old 12-06-2015, 03:01 AM   #6
Gmc.guy
Gmc.guy's Avatar
Good to hear it helped. Must have been jammed or dry Or maybe worn splines
-Cody
Thread Tools
Display Modes
