Old 12-06-2015, 08:28 PM   #1
Bandit130
Bandit130's Avatar
74 C10 Blower Switch
74 C10 350/TH350 w/AC. The blower motor switch has 4 speeds, but no off. Fan runs all the time on lowest speed. If my memory serves me right, this is what GM called "flow through ventilation". I'm not a fan of this. Is there a way to disconnect the low speed where it would then become off and the other 3 speeds work?
TIA
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 12-06-2015, 11:19 PM   #2
Jeramy
Jeramy's Avatar
Re: 74 C10 Blower Switch
on my 81 fan shuts off when you put mode selector in off position
1981 Silverado C10 LS/4l60e
My truck may be loud and ugly but I love her like bacon
Jeramy is offline   Reply With Quote
Old 12-06-2015, 11:29 PM   #3
chrismoore701
chrismoore701's Avatar
I heard the older trucks had the fan always run on low to help evacuate the exhaust fumes from the cab
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 12-06-2015, 11:42 PM   #4
Bandit130
Bandit130's Avatar
I have done that and fan still blows coming thru the ac vents. I have been setting it on heater and cold or defrost and cold. Still blows thru defrost vents. Just have not found a way to completely shut it off yet.
Mopar by Birth
Chevy by Choice
Old 12-07-2015, 12:53 PM   #5
tucsonjwt
My 73, 76, and current 83 all had constant low speed fan on due to "flow thru ventilation."
If you search this forum you will find some who have disabled the constant fan on wire, or just disabled low speed altogether.
I have never considered it to be a problem, but I live in the usually too hot desert.
tucsonjwt is offline   Reply With Quote
Old 12-08-2015, 12:24 AM   #6
TrailerTrash
TrailerTrash's Avatar
Im pretty sure there is a wire that can be snipped on the switch plug that will disable the constant on and actually make the lowest position the off position.
im sure someone will chime in with more info
TrailerTrash is offline   Reply With Quote
Old 12-08-2015, 11:52 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
i clip the jumper wire at the switch,78 shown
my 78 non AC is three speed,<- winter truck
my 79 non AC is four speed, ,<- summer truck
both low speeds clipped.
But I'm going to switch in a 79 4 speed into the 78 (= 3 speeds plus off)
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-08-2015, 01:17 PM   #8
Bandit130
Bandit130's Avatar
Thanks for the info. The pic is a little fuzzy. Is that a brown wire in the connector that you clipped? I have one connector w/4 wires and one w/1 wire on back of switch.
Mopar by Birth
Chevy by Choice
Old 12-08-2015, 02:03 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
yes its brown
John
Old 12-08-2015, 11:44 PM   #10
cadillac_al
74 and 78 both have the brown wire that needs to be clipped to disable low? I'm not a fan either.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 12-09-2015, 12:31 AM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
in the 78 and 79 it was brown,but it was obvious the small loop was the jumper
John
Old 12-10-2015, 09:51 PM   #12
Bandit130
Bandit130's Avatar
Thanks to all who have replied to this subject. I decided to perform an experiment to see if by removing wires, one at a time, from the switch connector and testing each fan speed position as to what would happen. The switch has 2 connectors. 1 4wire (brown, blue, green, orange). and 1 1wire (orange). The switch, as a lot of you know, is a vertical switch with 4 speeds. Low, Med1, Med2, High, position from bottom to top. Removed 1 wire at a time, tested, reinstall wire and removed another wire, tested, etc.
This is the results,
Removed Brown wire-fan speed-L,L,L,L
Removed Blue wire- fan speed-L,M1,L,H
Removed Green wire-fan speed-L,L,M2,H
Removed Orange wire-fan speed-L,M1,M2,L
This apparently cannot be done by the removal of any one wire from connector or cutting (clipping) wires, to disable low fan.
Any combination removal results in a Low fan at all or any combination thereof.
I am ready to believe that it may not be able to be done or by having no fan at all at any speed. Oh well, I guess I can live with it after all cause that was enough work as it was.
As for the 1 wire connector, it appears to go to the climate control, possibly for the AC so when using AC the Low setting turns off compressor. That is my conclusion of the single wire.
Any other suggestions would be appreciated.
Mopar by Birth
Chevy by Choice
Old 12-11-2015, 12:21 AM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
Can you get a picture?
See if we can figure this in the am?
John
Thread Tools
Display Modes
