Old 12-11-2015, 09:52 PM   #1
chrismoore701
chrismoore701's Avatar
Windshield thickness
I just picked up a new windshield for my 79 c10. Do you guys know what the thickness is? I have another windshield same size but thicker. Not sure what year it is
Thoughts Does the thickness even matter?
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 12-13-2015, 07:54 AM   #2
chrismoore701
Re: Windshield thickness
Any thoughts?
Chris
Old 12-14-2015, 02:53 AM   #3
andrewmp6
Are both oem or is one a aftermarket piece?
andrewmp6 is offline   Reply With Quote
Old 12-14-2015, 07:47 AM   #4
chrismoore701
I don't know about the one I had. Says PPG on it. The one I bought I know is after market
Chris
Old 12-14-2015, 10:44 PM   #5
chrismoore701
The old windshield I have is 0.2514" thick the new windshield is 0.1920". A difference of 0.0594". Does not seem like a lot. But is that enough to cause issues? I bought my weather striping from classic auto parts. That and the windshield are listed for 73-87. So it's not like I could get a different set up. Should I be concerned or am I over looking this?
Chris
Chris
Old 12-15-2015, 02:28 AM   #6
andrewmp6
I would try installing it see if everything fits with out any leaks,Some will use a little m3 auto bedding and glazing around the body side to make sure the gasket/weather striping seals fully.
Old 12-17-2015, 07:15 AM   #7
chrismoore701
I have already installed the trim on the truck. Should I remove it to add sealant? What about around the glass? Should I put any sealant there?
Chris
Old 12-17-2015, 09:15 AM   #8
andrewmp6
Unless you start to see any water leaks i would leave it be.
Old 12-17-2015, 09:58 AM   #9
chrismoore701
What about between the gasket and the glass?
Chris
Old 12-20-2015, 11:10 AM   #10
Axle
Axle's Avatar
If you have new gaskets, it shouldn't be a problem, install it the way the factory did and sleep well at night.
Alex.
Axle is offline   Reply With Quote
Old 12-20-2015, 11:54 AM   #11
chrismoore701
I talked to precision and they told me what types of adhesive to use and all is good. Installed last week and went well
Chris
Thread Tools
Display Modes
