Old 12-15-2015, 10:52 PM   #1
Ram-Man
Ram-Man's Avatar
Porterbuilt 8 Lugger
I started on the 67 3/4 ton GMC I picked up last summer. Porterbuilt stage 2 rear, stage 1 front and keeping the 8 lugs. Disc front and rear with 20" wheels. I'm not tearing this one down to the frame. I know from experience the amount of time it takes and they don't always get put back together. The truck was a 1 owner with 50,000 miles on it has had 1 repaint and is 99% rust free. Here are some pics.
Ram-Man is offline   Reply With Quote
Old 12-15-2015, 11:02 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Porterbuilt 8 Lugger
Nice
Hart_Rod is offline   Reply With Quote
Old 12-15-2015, 11:02 PM   #3
Ram-Man
Ram-Man's Avatar
more
Old 12-15-2015, 11:05 PM   #4
Ram-Man
Ram-Man's Avatar
cutting off all the leaf spring parts
Old 12-15-2015, 11:08 PM   #5
Ram-Man
Ram-Man's Avatar
Bags. Ghetto fill right now but will have a compressor and tanks.
Old 12-15-2015, 11:24 PM   #6
Ram-Man
Ram-Man's Avatar
Last pic. The Porterbuilt parts are superior quality. The welds and fabrication are top notch. The only problem I ran into being a 3/4 ton and having a dana 60 rear is the lower shock mount is a little to close to the rear. Solution is add thin lowering blocks to move it all down.
Old 12-16-2015, 01:58 AM   #7
swamp rat
swamp rat's Avatar
First off nice truck! and glad to see it not being torn apart for a frame off.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-16-2015, 10:43 PM   #8
ruddbow
ruddbow's Avatar
subscribed! love it.
ruddbow is offline   Reply With Quote
Old 12-16-2015, 10:59 PM   #9
redbaron
redbaron's Avatar
I'm in. Nice truck and plan.
Mike
1972 C10 Cheyenne SWB Black Supercharged Project
1972 K10 Cheyenne SWB Copper and White http://67-72chevytrucks.com/vboard/s...d.php?t=654175
1969 Camaro Protouring LS7 T-56 Project
redbaron is offline   Reply With Quote
Old 12-16-2015, 11:27 PM   #10
flashed
Im in to see more ,nice truck to start with.
flashed is offline   Reply With Quote
Old 12-17-2015, 01:14 AM   #11
'68 Newtricks
'68 Newtricks's Avatar
Are you doing the suspension, brakes, and wheel stuff and calling it done? Truck looks real nice...
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 12-17-2015, 09:45 AM   #12
Ram-Man
Ram-Man's Avatar
Yes that is the plan. Keeping it simple porterbuilt front and rear Viair compressor and tanks, disc front and rear, newer style steering gear all ball joints and tie rod ends. I'll try to post more pics of the truck later. It's original right down to the keys.
Old 12-17-2015, 10:08 AM   #13
lolife99
67-72 parts collector,…
lolife99's Avatar
Such a COOL build.
I know the purist wil chime in, but I love the direction you are going and keeping it 8-lug will make it even more unique.
This is what member way2lo2 has used to make LOTS of money on old vehicles.
He calls it the SDR,... or "stop, drop, and roll" treatment.
Good brakes, low suspension, and cool wheels.
Keith
Convert to disc brakes.
Old 12-17-2015, 10:33 AM   #14
BossHogg69
motor exploder
BossHogg69's Avatar
Wow, what a nice truck. Cool build - way to let those nutz hang and air out a 3/4 ton! That's gonna be a bad motherlugger (sorry, I couldn't resist)
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 12-17-2015, 11:56 AM   #15
BlueBullet
BlueBullet's Avatar
Did you find that beauty in Minnesota?
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 12-18-2015, 07:09 PM   #16
Ram-Man
Ram-Man's Avatar
Yes I did. It was traded in at a Chevrolet dealership.
Old 12-18-2015, 07:16 PM   #17
Ram-Man
Ram-Man's Avatar
Got the lowering blocks in to correct the problem with the jumbo differential. Also got the tanks and compressor location figured out.
1" lowering blocks in and lower shock mount is all good now.
Old 12-19-2015, 11:00 AM   #18
cooperhw
cooperhw's Avatar
I am in for this one. Love the way you are approaching it. I have a C30 dually short-bed that I am considering lowering in the future. This same kit should work for me. I will be following along. I don't want to tear mine all the way back down either.
Nice truck.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 12-19-2015, 06:37 PM   #19
Ram-Man
Ram-Man's Avatar
Nice truck.
I think your C30 frame has larger frame channels. I'm not sure but the notch might not work.
Old 12-19-2015, 06:45 PM   #20
Ram-Man
Ram-Man's Avatar
Put the box back on to try and figure out tire size. I am surprised these big rubbers will tuck in the wheel wells with room to spare. With snow on the ground I was pleased to see the rear is a posi. Hopefully start the front tomorrow.
Wheels I'll be using
Old 12-20-2015, 10:43 AM   #21
nlped
nlped's Avatar
I'm in on this one. Very cool!!
And, ole Cooper won't have an issue making stuff fit on his C30... He's a modifying/overcoming machine
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 12-20-2015, 12:16 PM   #22
69 MOD
69 MOD's Avatar
Sweet GMC!
Nice to see a fellow Minnesotan on the boards!
Someone should arrange a MN summer get together, I think there are a few of us around.
MOD
Chad
'71 GMC 2500 Custom Ol Blue
'72 Custom Deluxe Highlander Stuffed Olive
'73 Trans Am
'13 Silverado 2500 Duramax Storm Trooper
69 MOD is offline   Reply With Quote
Old 12-20-2015, 02:11 PM   #23
doo142
doo142's Avatar
That truck is so nice and original I'd be hard pressed to not run those stock wheels and caps! Looks nice with them tucked like that.
doo142 is offline   Reply With Quote
Old 12-20-2015, 07:16 PM   #24
cooperhw
cooperhw's Avatar
EXACTLY WHAT I was thinking Ed. Figured it would get me close, & I would take it from there. My DAd used to say "I could tear up a steel anvil with a rubber Mallett. Now I know what he meant. It's all good. Still think this kit looks sweet.
Later,
Wayne
Old 12-20-2015, 07:46 PM   #25
too much stuff
Roadtrip!
too much stuff's Avatar
Looks good. I vote for the old wheels and caps...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Thread Tools
Display Modes
