12-16-2015, 07:58 PM | #1 |
New! Pro Performance Dual 3 Gallon Tank Air Management Kit
New!
We just came out with our new Pro2 Air Management kit that uses (2) AccuAir tanks for each side of the frame rail. These are mounted on the AccuAir Exo Mounts for a clean and simple install. If you add the ECU/VU4 mount, this make for an easy installation of air management on your C10. We will be offering free shipping on this kit until the end of January. Kit comes with all the lines and can be upgraded to a SwitchSpeed to E-Level system. We have also revamped our other Pro2 kits, to now include the AccuAir tank as a standard. http://www.azproperformance.com/Pro2...t-200-PSI.html Pro2 63-87 C10 Air Management Kit Includes: 2 - AccuAIr Exo Mount Rings w/ Compressor Mounts 2 - VIAIR 444C Black Compressors (200 PSI) 2 - AccuAir 3 Gallon 200 PSI Rated Aluminum Tank (7 Port) 2 - AccuAir Exo Rings w/ Compressor Mounts 1 - AccuAir VU4 Valve Block 1 - AccuAir 3/8" Exhaust Mufflers 1 - Loctite 545 (10ml) 1 - AVS Arc-7 Switch Box 2 - VIAIR 160 PSI Black Face Gauges, Illuminated 1 - 165/200 VIAIR Pressure Switch 1 - 250 PSI Safety Valve 2 - VIAIR 40A Relays 1 - 60A Inline Fuse Holder 2 - Drain Valves 1 - 50 Ft. of 3/8" DOT Approved Air Line (Bags) 1 - 60 Ft. of 1/4" DOT Approved Air Line (Gauges) 4 - 1/8" FNPT - 1/4" Barb 4 - 1/4" MNPT to 1/4" Hose, 90 Degree 1 - 1/8" MNPT Plug 4 - 1/4" MNPT Plug 2 - 3/8" MNPT Plug 2 - 1/4" MNPT to 1/4" FNPT Elbow 2 - 3/8" MNPT to 3/8" Hose, 90 Degree 4 - Bag Fittings |
02-06-2016, 03:47 PM | #2 |
Re: New! Pro Performance Dual 3 Gallon Tank Air Management Kit
Im looking a buying this kit. what is the difference in the sizes of the bag fittings, any benefit of one size over the others? Thanks
02-08-2016, 10:44 AM | #3 |
You will just want to match up your bag fittings to the size of port in your bags. If you are using a AirLift D2600, we would get you a 1/2" MNPT fitting to thread directly into the bag.
02-08-2016, 12:17 PM | #4 |
Any deals for everything with E-level with touchpad + ECU mount + 4 bags? Any active duty military discounts?
02-08-2016, 01:22 PM | #5 |
Thread Tools | |
Display Modes | |
