Old 12-17-2015, 12:10 AM   #1
Bob Q
Brake Warning light on '83 K2500
While coming to a stop the other day in my '83 K2500, the brake warning light came on the dash. When the light came on, I felt something odd in the brake peddle almost like the proportioning valve popped out of center so I let off the brake and pressed it again and the light went off. I thought this was a little weird, but it never did it again that day. A day or so later, while coming to stops, it did the same thing as before; the warning light came on and it felt like the valve popped out of center again. Each time it does this, I can let off the peddle and step on it again and the light goes out and the brakes feel normal. So, I thought it may have had air in the lines so I bled all four corners and never got any air out; everything seemed ok. The master cylinder never loses any fluid and I don't see signs of leakage at any of the brakes. Also, the brake peddle doesn't bleed down (like a bad master cylinder). Any suggestions? Could it possibly be a bad proportioning/combination valve?
Thanks.
Bob Q.
'83 K2500 6.2L
Bob Q is offline   Reply With Quote
Old 12-19-2015, 01:06 PM   #2
Bob Q
Re: Brake Warning light on '83 K2500
Any ideas?
Thanks.
Bob Q.
'83 K2500 6.2L
Old 12-19-2015, 03:34 PM   #3
Liberty
Liberty's Avatar
Isn't that brake light only for when the parking brake is engaged?
Liberty is offline   Reply With Quote
Old 12-19-2015, 06:13 PM   #4
Bob Q
It's for both the parking brake and the proportioning valve to let you know when it's out of center.
Thread Tools
Display Modes
