Old 12-19-2015, 07:50 PM   #1
C10CONFUSED82
Vibration
Gents,
I have a slight vibration when I am traveling between 50 and 60 mph. I feel it all over pedal and steering wheel. Its seems to be also shaking the whole car. Could this be a issue with the 5.3 LS swap I have on the truck. Meaning could this be a issue with the cross member or motor mounts?
C10CONFUSED82 is offline   Reply With Quote
Old 12-19-2015, 08:12 PM   #2
MikeB
MikeB's Avatar
Re: Vibration
More than likely it's something in the drive line, such as as a slightly bent or out-of-balance drive shaft, or maybe an improperly installed u-joint.
Is it RPM or road speed related? In other words, does it vibrate at 50-60 even in a lower gear?
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 12-19-2015, 08:42 PM   #3
C10CONFUSED82
Re: Vibration
Not sure, I have not noticed it at lower RPMs but it does go away when I go faster.
Old 12-19-2015, 10:06 PM   #4
lightningtruck
Re: Vibration
Front wheel not balanced or loose lug nuts? Separating rubber on a tire?
I have had a wheel weight fly off and cause the same vibrations. Good luck!
Mike McGinnis
1990 V3500 Crew Cab build http://67-72chevytrucks.com/vboard/s...d.php?t=559196
1983 C10 Step Side Old Friend http://67-72chevytrucks.com/vboard/s...45#post7266145
lightningtruck is offline   Reply With Quote
Old 12-19-2015, 10:06 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Vibration
make sure the front end is tight and make sure you tightened up all the motor and trans mounts
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-19-2015, 10:44 PM   #6
Houston Ben
Houston Ben's Avatar
Re: Vibration
C10confused82,
I also have an LS swap and have a bad vibrations that starts about 45 mph and stays at any speed above it. I have tried many things. I have a new drive-shaft, new rotors and pads, new alignment,, new axles, seals and bearing, new tie-rods, etc. and still have the vibration. If the vehicle is in park or neutral and I rev the engine there is no vibration. The only think I can think of now is the transmission angle is too much. I bought a high hump trans cover that I will be installing along with a new trans cross member which I will install next week to see if this takes care of the issue. If it doesn't than I am at a loss. I is driving me nuts and makes the truck no fun to drive.
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532
Houston Ben is offline   Reply With Quote
Old 12-20-2015, 07:11 AM   #7
LeesTruk
Re: Vibration
Have you checked your driveline inclination? That's where the trans. output shaft angle should be within 3*-5* of the differential pinion angle (opinions vary on the degree but it's usually within that parameter). It's easy to find, using a simple and inexpensive angle finder bought at the local hardware store or big box outlet (Lowes/Home Depot)
LeesTruk is online now   Reply With Quote
Old 12-20-2015, 09:33 AM   #8
geezer#99
geezer#99's Avatar
Re: Vibration
Some info to figure out vibrations.
http://www.drivetrain.com/parts_cata..._problems.html
Or this.
http://www2.dana.com/pdf/J3311-1-DSSP.pdf
Old 12-20-2015, 11:07 AM   #9
cadillac_al
Re: Vibration
c10confused sounds like a wheel balance issue. I have never had a perfect balance so I never expect it. Mine will vibrate around 62 mph and goes away completely at 65 mph. Houston Ben sounds like he has an annoying driveling angle problem. That will take some work.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 12-21-2015, 10:48 PM   #10
barry1982
Re: Vibration
Do you have a two piece drive shaft? Had a similar problem with a truck a picked up a few years ago. Turns out the previous owner replaced the ujoints. When he reassembled, the weights on the front section and rear section were opposing, causing the vibration. The weights on both front/rear must be on the same side. I would have NEVER figured this out.... an old Mechanic buddy of mine "clued" me in....
barry1982 is offline   Reply With Quote
Thread Tools
Display Modes
