01-04-2016, 04:27 PM | #1 |
Lowering/Tire size quetions
I have a 1982 Chevy C-10 stock suspension, Cragar 15x8 Street Star wheels. I currently have 255/60-15's on the front, the narrowest tires I thought I could safely fit on the 8" wheels (should have bought 6"). On the back I have 275/60-15" Nitto 555R drag radials. The truck makes about 475hp/550ft-lbs via a 388/4L80e combo and is mostly Sunday driven but sees the drag strip occasionally. I want to lower the truck so that the fender openings sit just level with the tops of the tires. I am looking for ideas on the best/most economical way to lower it and still be able to maintain the most driveability. At some point in my dumb teenager years I bottomed out the truck hard enough to bend/roll the lower control arms slightly at the bushings. Will that affect much or should I just live with it as I have been?
01-04-2016, 10:13 PM | #2 |
Diggin The SquareLife
Re: Lowering/Tire size quetions
Go with a 4/6 i had 5/7 on 15x8 and 15x10 and i would recommend new control arms
01-04-2016, 11:15 PM | #3 | |
What part of Garland? I have in-laws in the Miller/Broadway area. |
01-05-2016, 04:11 AM | #4 |
Dont have any pics right now but you can look at my build thread an yea i would stay away from control arms go spindle and springs or just some 3" belltech spindles and a flip kit and stay around south garland of broadway
01-05-2016, 12:04 PM | #5 | |
Drop spindles & springs are the way to go for the front.
01-05-2016, 09:09 PM | #6 |
I have a 3.5/5 drop with factory control arms, I do have 17's though.
If you go more than 5" in the rear you will probably have to start notching the frame, with the 5" flip kit I did, I didnt notch. [IMG]http://i190.photobucket.com/albums/z72/jstndrfr/image_zps1qxpc [IMG]http://i190.photobucket.com/albums/z72/jstndrfr/image_zpsi2k [IMG]http://i190.photobucket.com/albums/z72/jstndrfr/image_zpszpdobub Last edited by Rangerman; 01-10-2016 at 11:25 AM. |
01-05-2016, 09:12 PM | #7 |
a flip kit for the rear and drop spindles and springs or stock springs with a coil taken off will yield a 4/6. It's a pretty economical way to do it for the large of a drop, though you should probably get shocks made for a lowered truck as well
01-05-2016, 09:14 PM | #8 |
Standard shocks work with the flip kits if you got shock extenders, same with the front, standard shocks are great.
01-06-2016, 01:15 AM | #9 |
I have the same tire and wheel size as you have in the front and a 2.5" spindle drop. My tires rub the fender lip with a decent bump in the road.
01-06-2016, 10:54 AM | #10 |
Backspacing affects things as well.
01-07-2016, 02:09 PM | #11 | |
Is there one brand of springs/spindles that's any better than the others? It seems that that people talk highly of Western Chassis flip kits and extenders, Is that right? |
01-07-2016, 02:22 PM | #12 |
Western Chassis (2.5") or Bell Tech (3") for basic lowering spindles. Both have high quality rear flip kits as well.
01-07-2016, 03:05 PM | #13 | |
I did the WC 2.5" drop spindle and their 1" drop coil springs in the front. In the rear I did the 5" flip kit, it will have your shock extenders and new perches, U bolts/hardware. Youll need to grind/cut of your factory bump stop brackets and simply use a 1" bump stop in place of the factory bracket. The 3.5/5 is a great everyday driving stance. |
01-07-2016, 03:18 PM | #14 |
Another thing to consider.... The amount of drop for the rear will vary depending on what spring pack the truck has. Trucks w/fewer leafs (4-6) will yield less drop vs trucks w/HD leafs (8 leaf pack).
01-07-2016, 04:21 PM | #15 |
It has 4 leafs and the 1" thick rotors.
01-07-2016, 04:25 PM | #16 |
Do you have a picture of yours that is a direct side view, not at an angle?
01-07-2016, 05:30 PM | #17 |
driving is in my blood
A 5/6 drop with 255/60/15's in front and 275/60/15's in back has been my go to standerd for almost 20yrs with 73-87's.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
01-07-2016, 07:50 PM | #18 |
01-23-2016, 06:14 PM | #19 |
Mine with a 5.5/7 and 245-60 / 295-50 combo (no motor) on top and a 5.5/8 255-60 / 275-60 combo (with motor) on bottom
Thread Tools | |
Display Modes | |
