Old 01-06-2016, 10:57 PM   #1
Kpfab11
Rear track width help for bagged guys???
Ok need some help. Trying to find the width from outside of tire to outside of tire that will clear the bedsides when layed out. The reason is I have a newer axle I am narrowing and am running some deep dish wheels and I don't have a bed yet that I can measure off. Thanks in advance
Kpfab11 is offline   Reply With Quote
Old 01-07-2016, 07:53 AM   #2
PGSigns
PGSigns's Avatar
Re: Rear track width help for bagged guys???
Have you got the tires mounted? What style bed are you going to run?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-07-2016, 09:20 AM   #3
Kpfab11
Jimmy
Going to be running a fleet side bed. Just really need to know what the width of the bed is at its narrowest point inside the fender wells
Old 01-07-2016, 09:36 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
If you have a 12 bolt or 10 bolt from a 70-87 gm truck then those rear ends are 1.5" wider than a 63-69. I run 8" ralley wheels and a 71 12 bolt and i can drop all the way down if i want to and wont rub anywhere.
Sorry i dont have the exact measurements for you.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-07-2016, 12:35 PM   #5
PGSigns
PGSigns's Avatar
OK how tall a tire and how low on the truck. Will make a difference on where to measure the bed. If you are going to end up past the point where the bed side rolls in it gets a few inches narrower on both sides in a matter of a couple of inches. So the measurements of the bed side below the body line will be about 5 inches wider then above the body line. When we tub a car we always have the wheel with the tires mounted and pumped up and put them under the car and set the car at ride height before measuring for a rear end. in your case it would be best to set the frame at the lowest height you plan to go and drop the tire and wheel in there with a bed on the truck. Tire heights and inflated widths can make a big change in placement. If you need a long bed I have one you can have, just ride up and get it.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 01-07-2016, 02:35 PM   #6
Pro Performance
Pro Performance's Avatar
The bed width inside the flat inner panel is 72". If laying on the ground, your wheels will come up that far and will have to stay within that 72" to clear. If you trim some of that ledge, you can gain just a hair more, but have to be careful. If you grind too much of that ledge off, it can separate the panel and will see it on the outside.
Hope this helps.
Pro Performance is offline   Reply With Quote
Old 01-07-2016, 03:16 PM   #7
Kpfab11
Thanks guys. I understand how to do everything. Just need a damn bed I could measure off since the 60-66 are impossible to find around here in nc. I'm running what I believe is a 71 12 bolt which measures around 64.5" wms-wms. going to be running a 28.5" tire laying close to rockers. If you are saying you can lay out with rally wheels all the way I guess that would be close to 72.5" outside to outside of tire.
Old 01-07-2016, 03:18 PM   #8
Pro Performance
72" is the measurement just inside that area. You can fudge a 72.5" with the trimming I mentioned. Would be close.
Old 01-07-2016, 03:21 PM   #9
Kpfab11
Thanks!
Old 01-08-2016, 07:47 AM   #10
PGSigns
PGSigns's Avatar
Been several beds for sale on this forum in NC over the last year. Jamie (62bigwindow) has has a couple.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 01-08-2016, 09:48 AM   #11
Kpfab11
Cool I'll check it out. I'm new to the forum. This was my first post lol.
Thread Tools
Display Modes
