Old 01-07-2016, 02:00 AM   #1
Super_Dave
Super_Dave's Avatar
Leaf Spring Questions
On my '74 C20 project, I am going with the C20 to C10 2.5" drop spindle kit. I am removing the 14bolt rear end and swapping in a '79 12bolt. I got the '79 after the dude cut off the spring perches, so I have to order a set. My questions:
(1) If I remove some of the leaves from the C20 leaf pack and delete the overload springs, can I use the C20 springs or should I go with some C10 springs?
(2) If I go with C10 springs, are the eyes the same width and diameter? Do I have to swap out the hangers and shackles or can I keep the C20 hangers and shackles?
(3) Are there differences in the spring perches that I need to consider before ordering?
Thanks in advance.
Dave
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair
"Life is tough - wear a cup!"
"Old Enough to Know Better - Too Young to Resist"
"Junk is something you will need three weeks after you throw it away."
Super_Dave is offline   Reply With Quote
Old 01-07-2016, 11:02 AM   #2
74CustomK20
74CustomK20's Avatar
Re: Leaf Spring Questions
They might not be the same legnth. You Either Have 56" Springs Or 52" Springs. Truthfully I would think taking out some c20 springs would ride better. But that's an opinion, take it as you want ya know. I'm taking out about 6 springs from my c30 pack and gonna see how that works. And in regard to width they'really both 2-1/2" wide. Same bolt size and all. All hangers the same you might just have to move the rear hanger assembly either forward-backward, or nowhere.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 01-07-2016, 12:09 PM   #3
Super_Dave
Super_Dave's Avatar
Thanks, I think I will do exactly that... remove some leaves and the overload springs, add shorter u-bolts and spring perches to the 12 Bolt and call it good.
Old 01-08-2016, 10:26 AM   #4
1970pelle
1970pelle's Avatar
74CustomK20 is correct in that C20 main rear leaf spring is longer than the main leaf on a C10. So it would be a easier job over all staying with the C20 spring and reducing the spring pack. And replacing the hangers and shackles. Don't forget new center bolts, they will be a larger size than the C10 center bolts.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels
2007 Lexus ES350 (wifes)
1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift
“There is no limit to the amount of good you can do if you don't care who gets the credit.”
― Ronald Reagan
1970pelle is offline   Reply With Quote
Old 01-08-2016, 12:07 PM   #5
Super_Dave
Super_Dave's Avatar
Ken
Hi Ken,
So, if I keep the C20 leaf springs that are on the truck and remove the overload springs and a few leaves from the main pack, do I have to replace the hangers and shackles?
Replacing the bolts with new makes sense given the 42 year old age of the current bolts.
Thread Tools
Display Modes
