Old 09-19-2003, 10:14 PM   #1
oldtrucknut
67-72 truck surgeon
Bearing Question
heres the case- front wheel, drum brakes
is it possible that a drum with a bad bearing could be turned in reverse (clockwise) but not be able to move forward (counterclockwise)? I am working on a car for someone and I lifted the car for another reason, and I noticed that the wheel bearings were not tight enough, so I checked to see if they would spin and that's when I found the problem. It will turn a little or turn real hard or turn freely then klunk! stops hard. The brakes are backed off all the way too. I cleaned the bearings and drums real well and repacked the bearings, thinking this would do the trick because there was a lot of dirt in the old grease. But it did the same thing when I put the drum back on. And when I have the bearings just a little loose and pull out on the drum it will spin better. I suspect the inner bearing, but when I cleaned them, they all looked decent. Oh, and by the way I am a loyal Chevy man who is working on a Mustang, so I really need some help here to get it the heck out of my garage!
1969 Chevy C10
1993 Toyota Camry LE
1999 Ford F250 Super Duty 4x4 diesel
2008 Dodge Charger Super Bee
1953 International R182
oldtrucknut is offline   Reply With Quote
Thread Tools
Display Modes
