Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 01-14-2016, 09:03 PM   #1
Pro Performance
Pro Performance's Avatar
Pro Performance - Now a Dirty Dingo Dealer!!
We are now offering the complete Dirty Dingo line up! We are excited to be offering these quality USA made parts for all the LS conversions. They have motor mount adapters, PCM mounting brackets, engine lift plates, accessory drive brackets, etc. We are slowly getting all the items uploaded to our site, and have done some already. If you don't see what you need, let us know and be glad to help you out.
Some of the products they offer.
Need conversion mounts? These slider mounts allow you to position the engine in the same location as your SBC, or move it forward if needed in virtually any spot with 2" of adjustability.
63-72 C10:
http://www.azproperformance.com/Dirt...63-72-C10.html
73-87 C10:
http://www.azproperformance.com/Dirt...-DD-2500C.html
Wanting to add a high performance or car intake onto a 5.3 truck engine? These spacers will allow you to run the Camaro/Corvette water pump, to allow clearance for the throttle body on lower intakes. These also have a provision for the steam port!
Water Pump Spacers:
http://www.azproperformance.com/Dirt...LS-WP-SP1.html
Looking for a good way to mount that PCM that has no mounting tabs?
PCM Mounting Bracket:
http://www.azproperformance.com/Dirt...-LS-PCM-1.html
Pro Performance is offline
Old 01-15-2016, 11:02 AM   #2
Pro Performance
Re: Pro Performance - Now a Dirty Dingo Dealer!!
Another great item they offer is the Sanden compressor bracket. This comes with the Gates idler pulley (doesn't have to be purchased separately like other mounts), and correctly lines up the belt to eliminate belt noise.
https://www.azproperformance.com/Dir...DEN-AC-TR.html
Old 01-20-2016, 02:15 AM   #3
Pro Performance
We also just posted a ton of LS swap information to our site. We now have oil pan dimensions listed, balancer dimensions, engine designations, etc. (Info pulled from Dirty Dingo)
General LS Swap Info
LS Oil Pan Dimensions
Old 02-11-2016, 07:05 PM   #4
Pro Performance
Ttt
Closed Thread
Thread Tools
Display Modes
