Old 09-20-2003, 01:37 PM   #1
Adam12
I hate trannys
Adam12's Avatar
Transmission cooler recomendations
I hear that these really make a big diffrence and was wonding what everyone is using? I looked into it a little bit and saw two diffrent types, the ones I ahvea lways seen that are like mini raidators and then I saw those straight long ones that look really cool, are those any good?
Thanks,
Adam
70 SWB 481 ci, TH-400, Edlebrok Victor Jr. intake, Holley street avenger 770, Dynomax ceramic coated headers. Dual flowmasters. and only 3516134 more little things to do.
Adam12 is offline   Reply With Quote
Old 09-20-2003, 03:01 PM   #2
jef5150
Inline 69
jef5150's Avatar
http://www.derale.com/transcoolers.shtml http://www.bmracing.com/ heres 2 places you can check out,,,,over cooling can be a bad thing also ,if i remember correctly trans temp should be 170-190 degrees,but if im wrong im sure ill get corrected,,,,,,,jeff
jef5150 is offline   Reply With Quote
Old 09-22-2003, 08:07 AM   #3
400ex
Well, from my experience I have not had any problems with the Hayden trans cooler that I picked up from Hi/Lo about 6 years ago. I picked out the one used for 10,000 GVWR. The measurements of it are approximately 14" long by 10" high. This is guessing but its pretty close to that dimension.
I looked at the one recommended for 1/2 ton trucks but I felt it was a little on the small side, so I bought one that was bigger.
James
400ex is offline   Reply With Quote
Old 09-22-2003, 08:54 AM   #4
MOTHERTRUCKERS
We use the MOROSO aluminum trans cooler, its a finned round heavy aluminum about 5" diameter by 14" long. We mount it on a 1" wide piece of strap steel accross the front of core support behind the grill bar on 67-70 trucks and higher on 71-2. I"m not real impressed on heater core type coolers becaues the fins damage to easily.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 09-22-2003, 09:12 AM   #5
Adam12
I hate trannys
Adam12's Avatar
Do you have any pics of that mounted mothertruckers? do you sell them and if so how much?
Thanks,
Adam
Old 09-22-2003, 11:50 AM   #6
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Mothertruckers, if you could get some pictures, I'd like that too. I have seen some similar coolers on e-bay going for the $30-40 range. I was wondering if they would work as well as the MOROSO brand? They have them in several lengths too. I was considering putting it along the frame rail, but I like the idea of putting in on the core support.
Here is one on e-bay now - http://cgi.ebay.com/ebaymotors/ws/eB...tem=2433318579
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 09-22-2003, 12:17 PM   #7
landon4421
Life is Good !
landon4421's Avatar
I got mine from summit a few years back it is a perma cool. I liked it, I had it on my '72 4x4 and it worked great. I am installing it in to my wifies burb now. I have it installed just need to get the lines run. I will post a pic, tonight. If you guys would like ! Landon
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 09-22-2003, 12:19 PM   #8
Adam12
I hate trannys
Adam12's Avatar
A pic would be great!
Old 09-22-2003, 12:24 PM   #9
70c10
67-72 Addict!
70c10's Avatar
I heard you also have to be careful of it keeping the tranny so cool it won't allow it to warm up in Winter climates. Is this true?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-22-2003, 08:33 PM   #10
MOTHERTRUCKERS
The one on ebay looks very simular to the Moroso cooler except the fins and mountings are thicker and they are not polished on the Moroso unit.
Old 09-22-2003, 08:57 PM   #11
Locutus
Locutus's Avatar
I think alot of people balance the heat by adding a external cooler inline with the radiator cooler. The radiator helps it heat up the external helps it cool down. My Chevy Z-71 was that way stock from the factory.
Locutus is offline   Reply With Quote
Old 09-22-2003, 09:26 PM   #12
Glen
I just mounted a B&M in front of my radiator, I used AN fittings with steel braided hose, put bulkhead fittings on the core support and ran more stainless hose from the core support under the battery to the tranny itself. Looks nice and clean with the fittings and bulkheads make it easy.
Glen is offline   Reply With Quote
Old 09-22-2003, 10:10 PM   #13
landon4421
Life is Good !
landon4421's Avatar
Adam12, here are a couple of pics for you ! I the cooler is # PRM-3311 That is the summit # from the book. Here is the pics !
Old 09-22-2003, 10:11 PM   #14
landon4421
Life is Good !
landon4421's Avatar
pic 2
Old 09-22-2003, 10:12 PM   #15
landon4421
Life is Good !
landon4421's Avatar
pic 3
Old 09-22-2003, 10:19 PM   #16
GMC JUNKIE TOO
THE QUICKER FIXERUPER
GMC JUNKIE TOO's Avatar
I am allso looking into a tranny cooler I read that the moroso finned coolers were not recomended for the street, I cant figure why unless they dont cool enough. The hi-tek b&m coolers sound good because they are stacked aluminum so they cant bend like the cheap ones.
GMC JUNKIE TOO is offline   Reply With Quote
Old 09-24-2003, 04:55 PM   #17
Adam12
I hate trannys
Adam12's Avatar
Does anyone know how the moroso coolers proform on the street? I really like the way they look but my truck runs pretty hot, so I will definatly need somthing that can cool good.
Old 09-27-2003, 11:43 PM   #18
Adam12
I hate trannys
Adam12's Avatar
So when I find the cooler that will work for me do I just use rubber hose to go from the tranny to the cooler? Right now I ahve some brake line that I bought and bent to go to the radiatior cooler. If somone could give me some instalation tips or point me to a page with some pictures or somthing that would be great. I have been lookin at the B&M coolers but dont know what GVW is or means...Any help would be great thanks.
Old 09-28-2003, 12:06 AM   #19
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
GVW= Gross Vehicle Weight the total weight of your vehicle. Plus whatever you are towing or hauling in or on the truck including driver and any passengers. Hope this helps.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 09-28-2003, 12:14 AM   #20
Adam12
I hate trannys
Adam12's Avatar
Yes, thank you. does anyone know what the avg weight of one of our trucks with a big block weighs? and any tips on the installation?
thanks again,
Adam
Old 09-28-2003, 12:48 PM   #21
Firefighter
Not positive but according to what I have for a 1/2 ton SWB with a V-8 it's 3742 lbs. LWB it's 3826 lbs. 3/4 ton LWB it's 4134 lbs. Longhorn is 4189 lbs. I don't know if that is with a big block or not, because it did not say but a 3/4 ton LWB with a 6-cylinder weighs 4001 lbs. That might be close to a big block's weight.
Yellville, Ar. USA
Old 09-28-2003, 02:14 PM   #22
Adam12
I hate trannys
Adam12's Avatar
thanks
Old 09-28-2003, 03:29 PM   #23
'72 Shorty
I finally got an avatar
'72 Shorty's Avatar
here's a pic of mine, just a generic cooler mounted inline after the stock in the radiator one. My trans temp runs about 150-160 when i'm cruising and about 200-210 in traffic. That's reading the temp of the fluid in the pan.
-72 C-10 short step (straight line only)
12.922/102.28
-69 C-20 on Propane (DD)
-69 C-10
-56 Mack B-753LS (tow rig)
-94 Chev K2500 Short Ex-Cab
-89 Isuzu Trooper...Kinda
-03 Kawasaki KFX-400
-05 Suzuki DRZ-400S
'72 Shorty is offline   Reply With Quote
Old 09-28-2003, 06:26 PM   #24
Firefighter
You're Very Welcome!! Glad to help!!
Yellville, Ar. USA
Old 09-29-2003, 02:38 AM   #25
Injected68LS1
Injected68LS1's Avatar
I have a hayden, stacked-core cooler. I bought the biggest one I could find. It is meant for a motor home. I have a 700R4 transmission and it is recommended to have a very cool fluid for long life. I typically have my trans. temp. just over 100 degrees when it is 90 degrees outside.
You will find that a stacked-core is more efficient and better then the fin and tube coolers. Simply stated, you can use a physically smaller one and have it cool better than the fin and tube.
I would recommend getting one that is 20000 GVW or better.
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Thread Tools
Display Modes
