01-17-2016, 03:16 PM | #1 |
Leaving car in gear - burning smell and squeak
Hey quick question. My 64 c10 has no ebrake cable hooked up at the moment (on order) so I am leaving the car in gear when I park it. When I start her up again and try to move I encounter some resistance and get a squeaking noise and a burning smell. Something has to be activating somewhere...I haven't gotten under just yet but is this something with the tranny or braking system?
Thanks for guidance |
01-18-2016, 01:16 AM | #2 |
60-66 Nut
Re: Leaving car in gear - burning smell and squeak
I assume this is a manual trans? I always leave my manual trans cars and trucks in reverse when parked and I've never had any of these issues.
01-18-2016, 01:20 AM | #3 |
Yes - me too. I tried to push the car as well in neutral and it wouldn't roll. The weird part is when I drove away it was sqeaking and burning as if the parking brake was on....going to have to get under and see whats up.
01-18-2016, 01:49 AM | #4 |
60-66 Nut
When was the last time you checked the oil level in the trans?
01-18-2016, 08:58 AM | #5 |
If it wont roll in neutral then there is something broke. Could be a stuck brake, a bad bearing in the rear end or the trans is toast.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
01-18-2016, 09:33 AM | #6 | |
01-18-2016, 12:01 PM | #7 |
Sounds like you have a seized/stuck brake. If it happens again, put truck in neutral and jack up and try to spin each wheel. That would identify your source.
01-18-2016, 01:16 PM | #8 | |
Moderator
01-19-2016, 07:12 AM | #9 | |
01-20-2016, 01:28 AM | #10 |
my wife was out shopping and she had a similar problem.
I went to get her and the car , it felt like the ebrake was on when I tried to move the car. she doesn't use the ebrake and it wasn't pressed down. after I managed to get it home . when I pulled the tight brake drum off . witch I had to adjust the brakes looser to get it off... the bonded brake lining had came loose from the brake shoe and it fell off when I got the drum off . the lining was binding up the rear brakes . I put some new brake shoes on and the problem was solved . it was a 94 buick roadmaster wagon .. |
Thread Tools | |
Display Modes | |
