coil spring rubbing
on the drivers side of my c10 [lowered 4.5 inches] the coil spring is not centered so it rubs and makes noise.the pass. side is fine.the drivers side wheel is back about a half inch from a accident before i purchased the truck.i just had the truck aligned and it drives fine.what would you guys suggest i do to move the spring back? image is the front of truck and front of spring.thanks
![]() Join Date: Jan 2016
Re: coil spring rubbing
I've got the same problem in drivers side. No idea what to do.
Me too. I think it happens because the coils are where they are. Like if you could rotate the spring it would have a void in that area and not rub. I am going to try to swap the springs from left to right to see if maybe they are different. I wouldn't think so but who knows.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Let us know what you find out after you swap them. I didn't have this problem with my old coils. Started yesterday when I put in new CPP coils.
Probably wont happen any time soon. I also did the lower control arm mod which may contribute to the issue. I will visit that thread to see if others have encountered this.
Thread Tools | |
Display Modes | |
