Old 01-28-2016, 03:34 PM   #1
cypressbog
Go Pack Go!
Rear gear ratio question
HO-52 with the following:
3682104
GM 7-32
1.54
Is this 4.57 ratio? 32 divided by 7?
cypressbog is offline   Reply With Quote
Old 01-28-2016, 03:40 PM   #2
davepl
davepl's Avatar
Re: Rear gear ratio question
Here you go... from SSTim originally I believe. Search is your friend :-) 3682104 decodes to the 32/7 4.57 ratio as you thought.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-28-2016, 04:31 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Rear Axle Ratios
Ratio 2.56:1 - Tooth Combination 41,16
Ratio 2.73:1 - Tooth Combination 41,15
Ratio 3.07:1 - Tooth Combination 43,14
Ratio 3.08:1 - Tooth Combination 40,13
Ratio 3.08:1 - Tooth Combination 37,12
Ratio 3.31:1 - Tooth Combination 43,13
Ratio 3.36:1 - Tooth Combination 37,11
Ratio 3.42:1 - Tooth Combination 41,12
Ratio 3.55:1 - Tooth Combination 39,11
Ratio 3.73:1 - Tooth Combination 41,11
Ratio 4.10:1 - Tooth Combination 41,10
Ratio 4.11:1 - Tooth Combination 37, 9
Ratio 4.57:1 - Tooth Combination 32, 7
The tooth combination numbers will be found stamped into the ring gear when you take the back cover off.
These may not all be for the trucks.
LockDoc
Leon
Old 01-28-2016, 04:53 PM   #4
cypressbog
Go Pack Go!
Awesome, thanks for the info. Now to find a 4:11
Thread Tools
Display Modes
