Old 02-05-2016, 05:24 PM   #1
slotard
Swapping carpet for floor mat - source?
My '73 C20 has a carpet that's pretty ugly. I'd like to swap to something that doesn't hold dirt/mud as much. Any suggestions for where to get a mat?
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 02-05-2016, 06:01 PM   #2
Malamute
Malamute's Avatar
Re: Swapping carpet for floor mat - source?
I'd guess you could find a rubber mat here.
http://67-72chevytrucks.com/vboard/s...d.php?t=588786
Malamute is offline   Reply With Quote
Old 02-05-2016, 08:39 PM   #3
Keith Seymore
Keith Seymore's Avatar
Site vendor Capt. Kaos.
See page 11 of my intro thread linked below for photos.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-06-2016, 12:59 PM   #4
tucsonjwt
The problem with the rubber mats (even the factory mat) is that they tend to bunch up around the center hump. LMC sell a thicker mat which might be better.
I just had the carpet replaced then bought Husky floor liners and covered the center hump with Walmart black exercise mat. There is a little dirt that collects around the edges of the liners, but I clean it out once a year and all is good.
A rubber mat (even the Huskyliners) will wear out where your feet go on the driver's side and eventually need to be replaced. That is why I favor Huskylliners. Weather Tech sells a similar floor liner - they are more expensive but look better. I have always put Huskyliners in all of my vehicles.
Huskyliner used to make a full width floor liner which went over the hump but I don't think the are still available.
One benefit of the Huskyliners is that when you have the inevitable leaks around the windshield or elsewhere, the Huskyliner will contain the water and not soak the floor.
Whatever you choose, make sure you have good insulation under the floor covering. You might consider the Dynamat type if your insulation is deteriorated, which it probably is.
Doing a good job with carpet or mat, insulation, and floor liners will cost $300-$400, so it is worth doing some research. If money is a consideration, I would buy Huskyliners or Weather Tech liners and hold off on the rest of the flooring. Floor liners will make a huge difference, especially in wet weather and muddy conditions. You can get liners for a decent price if you shop around online.
tucsonjwt is offline   Reply With Quote
Old 02-06-2016, 03:22 PM   #5
MikeB
MikeB's Avatar
You can get OE-style, molded vinyl floor covering with jute backing at RockAuto for less money than just about anywhere else ($105-$109). Looks like color choices are black, medium blue, beige, and gray. The manufacturer is Auto Custom Carpets.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 03-02-2016, 03:31 PM   #6
slotard
http://www.rockauto.com/en/moreinfo....031836&jsn=436 is that what you're talking about?
1973 C20, 350/350
Old 03-02-2016, 04:21 PM   #7
midnight rambler
midnight rambler's Avatar
freds truck parts
midnight rambler is offline   Reply With Quote
Thread Tools
Display Modes
