02-08-2016, 10:26 PM | #1 |
Master Cylinder access hole lid
I cut a hole in my floor of my '53 for access to the new master cylinder, and need to cover it with the patch I cut out. How did others do this? Hinges, etc? Any pics? Thanks.
02-08-2016, 10:42 PM | #2 |
Re: Master Cylinder access hole lid
if it is round the bodyshop supply places sell nice rubber plugs that work pretty well. is it round or square? if you have another piece of sheet stock laying around you can cut a piece just a bit bigger with a flat side on it and rivet or weld it centred over the old piece, then hinge that flat side and put some weatherstripping on the overhung part, or cut a piece of small vacuum hose end for end so it is slit down the side, then glue that to the edge of the old hole and when the new lid is snugged down it seals against the rubber tube. like cheap guys weatherstripping. a small machine screw stud, put through from thr bottom side and held in place by a speed nut or welded, could be used to hold the lid down, opposite the piano hinge. a pic would really help us understand what you have there and how much room you have to work with.
02-09-2016, 12:31 PM | #3 |
here is mine. scrap metal, piano hinge piece, thumb turn and quick nut. Not shown is wiper hose used for gasket. I set up my seat to tilt forward for access.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
02-09-2016, 02:24 PM | #4 |
02-09-2016, 03:32 PM | #5 |
all I can say is make it big enough to pour fluid through without making a big mess. and, nice job guys.
02-09-2016, 03:36 PM | #6 |
oh ya, one other thing to mention. some newer cars have a hole in the floor under the drivers and passenger's foot area. it is plugged with a nicely shaped stamped metal plug with "wings". next time you are under a newer car take a look to see if anything like that would be useable. usually they are just glued in with that really nice body glue that is almost like a weld. may be a little hard to get out but may also make a nice plug for something like that. trunks also have these drain hole plugs. another place to check would be under the rear seat of some imports. the fuel pumps have an access hole there. some have rubber plugs and some have a nice metal plug with attachment wings. vw and Honda come to mind. you could google for pic to get relative sizes. maybe?
02-09-2016, 03:37 PM | #7 |
Big enough to get your hand through too.
I've crawled under the truck, popped the cap and filled the master cylinder with a squeeze bottle with hose attached for years but that sure isn't any fun at all. Being able to tilt the seat forward, or remove the seat easily would be a plus.
02-09-2016, 04:38 PM | #8 |
52 Chev 1300,55 235 40 over, 848 head, dual Edelbrock intake, Fenton headers, CW 32/32 carbs, 251 cam, HEI, T5 Trans, 3.23 rear, 235/75/r15 rubber. If it aint broke I still try to fix it! |
02-09-2016, 04:42 PM | #9 |
RV shops also have some nice stuff as well as fab shops for stuff like work truck decks etc. an electrical supply outlet may have a lid from a waterproof box that you could make work as well.
02-16-2016, 02:37 PM | #10 |
i always used a piece of stainless polished on one side to act as a mirror so when i checked fluid i could see. always used large syringe with clear tubing from below so zero chance spillage on carpet.
02-16-2016, 03:04 PM | #11 |
how about the lid and part of the sides from an army ammo box. sealed really well and big enough to get your hand through no problem.you could cut it off, flange the sides out and screw it to the floor if you don't fancy welding under there. seal it up after and -boom- bob's your uncle.
02-16-2016, 03:28 PM | #12 | |
(look at the second post in this topic i started about the same thing *1project2many* shows a picture of the panel) , it should give you plenty of room to get your hands in there or a bottle of brake fluid or whatever , and keep all the dirt from falling into the master cylinder http://67-72chevytrucks.com/vboard/s....php?p=7416518 |
Thread Tools | |
Display Modes | |
