Old 02-11-2016, 05:41 PM   #1
sharkskinman
thoughts on this pic of #1 piston
Decided to take head off and replace some gaskets
I did wire wheel it first
Thoughts??
sharkskinman is offline   Reply With Quote
Old 02-11-2016, 07:05 PM   #2
jtrichard
Re: thoughts on this pic of #1 piston
burnt piston NOT GOOD
jtrichard is offline   Reply With Quote
Old 02-11-2016, 08:17 PM   #3
chevy2tom
chevy2tom's Avatar
Paperweight
chevy2tom is offline   Reply With Quote
Old 02-12-2016, 09:08 AM   #4
kwmech
What does number 6 look like
Old 02-12-2016, 01:59 PM   #5
TJ's Chevy
TJ's Chevy's Avatar
Not good.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 02-12-2016, 02:41 PM   #6
sharkskinman
All others look good
Replaced some gaskets including head gasket..
All u can do for now is seal it up, button it up and drive it till new engine
Old 02-12-2016, 11:16 PM   #7
70STOVEBOLT
70STOVEBOLT's Avatar
Looks like detonation damage.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-13-2016, 03:09 AM   #8
chevybuldr
chevybuldr's Avatar
Yea that isn't going to work at all. The top ring is blown out and compassion is going to just go no where but in the pan. If that thing doesn't smoke or use oil I will be shocked.
chevybuldr is offline   Reply With Quote
Old 02-13-2016, 03:12 AM   #9
kwmech
That's why I asked about #6. The end cylinders tend to run lean
Old 02-13-2016, 04:03 PM   #10
frankslagoon
I haven't messed with gm inlines for awhile. can he push the piston /rod ass. up and replace the piston?
frankslagoon is offline   Reply With Quote
Old 02-13-2016, 05:54 PM   #11
TJ's Chevy
TJ's Chevy's Avatar
He could, but I do wonder how bad the cylinder wall is damaged.
Old 02-13-2016, 06:12 PM   #12
sharkskinman
Inside cylinder looks fine
Can't be without it long enough to replace the piston..
I am looking for 1 for a replacement
But can't imagine changing it unless I plan on re ringing it tho
Old 02-13-2016, 07:18 PM   #13
TJ's Chevy
TJ's Chevy's Avatar
And a re-ring means honing the cylinder as well so the new rings will seat properly.
Old 02-13-2016, 08:42 PM   #14
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I was thinking "PING Damage" as well...Fix that and that thing might surprise you how long it will last, especially with the timing retarded a bit...? Timing and/or bad gas and high compression...?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 02-13-2016, 10:56 PM   #15
haysonj
haysonj's Avatar
I may have got lucky but I had a 67 with a six in it and I replaced one piston only with new rings on the one piston and the truck ran fine for two years and was still running when I sold it. The old sixes are pretty forgiving and are not a high rpm race engine.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 02-14-2016, 03:03 PM   #16
sharkskinman
Timing set at 4*
Some have suggested to up that..to what tho??
If I can get its smoking to a minimum then it can wait till another engine
But graces is that it's at the front so I guess I can lift it up enough to get that one out and replace it maybe
Anyone got a couple good used to get rid of?? Pay it forward possibly??
Old 02-14-2016, 04:02 PM   #17
sharkskinman
Compression test
#6-145
#5-150
#4-160
#3-140
#2-140
#1-30..oil in-60
So now need piston and it will be straight till new engine!!
Old 02-14-2016, 04:24 PM   #18
sharkskinman
What would I have to take off to simply tilt the motor up enough to get pan off and get to rod bolts?
Probably change some gaskets n 2 piece seal while I'm at it
Thread Tools
Display Modes
