Old 02-18-2016, 02:33 AM   #1
1981 C20
Fuel Gauge Way Past Full
I'm a newbie to this forum with average to decent mechanical skills, but my understanding of electrical issues is subpar - so I could use some assistance. My '81 C20 with dual fuel tanks is having fuel gauge issues. When I bought the truck a month ago, only the right fuel tank was usable and the gauge measured it's contents reliably. After doing some research on this forum, I decided to replace the fuel tank selector valve in an attempt to use both tanks. Now, after paying a mechanic to have the valve replaced and the left tank full and the right a couple gallons shy of empty, the gauge reads significantly past full all the time, no matter which tank is selected. The mechanic said he could source the issue and fix it, but it may take him several hours. I'm afraid that his bill, when it's all sorted out, will tap me dry if I have him work on it any further!
Could the switch in the cab be the source of my problem? Or something else?
Any help would be appreciated. Thanks.
1981 C20 is offline   Reply With Quote
Old 02-18-2016, 08:15 AM   #2
Dead Parrot
Re: Fuel Gauge Way Past Full
IIRC, a reading way past full, guessing yours is at about 3 o'clock, is a missing or bad ground from the tank in question to the frame.
Since one of yours was working properly before the repair attempt, thinking that somehow you lost ground on both tanks. On mine, there is a wire that runs from the tank sender to the frame. Not easy to get to and both ends are exposed to both rain and road splash. After 30+ years of corrosion, probably worth checking out.
Another possibility is the mechanic either bought the wrong switch or connected it wrong.
Dead Parrot is offline   Reply With Quote
Old 02-18-2016, 11:18 AM   #3
1981 C20
Thanks! Yes, you are correct - the gauge is constantly at the 3 o'clock position. I'll start with the ground connection. What is the best way to access the wire? Would be easier to unbolt and remove the bed to get at the wire than to remove both tanks since both are now full? I suppose the other option is to keep an eye on the odometer until both tanks are near empty and then drop the tanks ...
Old 02-18-2016, 01:23 PM   #4
Jeepwm69
My 83 did that and the pink wire from the tank was actually cut in half. I spliced it back together and the gauge worked fine after that.
No idea how it got cut, but it was cleanly cut.
Jeepwm69 is offline   Reply With Quote
Old 02-18-2016, 04:21 PM   #5
Dead Parrot
If you need to replace the ground wires at the tank, removing the bed is probably easier if you have several self portable bed lifting units you can bribe with sufficient quantities of recreational beverages. Plan on replacing the 8 bed bolts and start treating with penetrating oil several days before the planned removal. (That 30+ years of corrosion again.) Also plan on replacing all of the rubber gas lines while you have easy access. Don't forget to unhook the wiring harness(es) at the back of the bed. I can speak from experience that dropping and installing an empty tank by yourself is a PITA.
Before doing the bed removal, I would double check the wiring at the switch since that is the last thing changed and one side was working before the mechanic touched it. Easier to do if you pull the ash tray first.
Old 02-18-2016, 04:28 PM   #6
slotard
I'll have to try adding a ground to my tank, right now my gas gauge is at almost 3 o clock and I've never seen it move.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 02-19-2016, 12:55 AM   #7
LBJ
Similar problem on my 77 Bonanza. Gauge goes way to the right when full and by the time it gets to 3/4 tank indicated, it's down almost 10 gallons. I'm used to it after 39 years, but it's a nuisance.
LBJ is offline   Reply With Quote
Old 02-19-2016, 04:01 PM   #8
dieseldawg142
dieseldawg142's Avatar
this^^
if it hangs at 3, the sender wire is most likely damaged. start at the switching unit & trace the pink. if you want to test it quick, cut the pink at the switcher, hook up a new wire, then tap back into the pink under the hood at the plug. it is faster than searching the entire wire, which is 30+ yrs old anyways....
mine was cut by a clamp.
dieseldawg142 is offline   Reply With Quote
Old 02-20-2016, 02:18 AM   #9
hatzie
Moderator
hatzie's Avatar
If it worked before he changed the valve then he fouled it up. He didn't finish the job. I wouldn't bring another vehicle to him and I wouldn't reward his poor performance by paying him to fix this.
Since it's not working on either tank I doubt it's the grounds. You can test this by measuring the resistance from the tank to the frame. If it's close to 0 ohms the ground is not the problem.
First place I'd look is the wire from terminal B of the valve to the bulkhead plug under the brake booster. In 1981 this will be a Pink wire with no stripe. There's a molded rubber disconnect in the wire not far from the Weatherpack connector on the valve. Verify that it is not disconnected... If your parts changer was too ham handed he could've disconnected it.
Another possibility is the sender switch in the valve is defective. Ohm it out with a meter.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Thread Tools
Display Modes
