Old 02-21-2016, 03:19 PM   #1
Tod59
350ci & stock steering ?
Hey guys, in the garage now with my 59 3100.
Question:
If I install a 1973 350 engine with a 700r4 tranny, can I still use my original steering box and column? My new auto shifter will be on the floor. But, I'm worried about having room for my original non power steering against the rams horn manifolds I want to use.
I'm on a TIGHT budget here, so no power steering upgrades, no new front suspension upgrades or used Camaro front clips. Just want to know if I can use original steering box and column.
Oh yes, I'm going to use 2 inch rams horn manifolds too.
Tod59
Tod59 is offline   Reply With Quote
Old 02-21-2016, 04:24 PM   #2
mr48chev
mr48chev's Avatar
Re: 350ci & stock steering ?
59 trucks came with 283 V8 engines that have the exact same outside dimensions as the 350. That means you are worrying about something that isn't an issue.
The only issue is that you will most likely have to remove or modify the crossmember that the bellhousing bolted to as it will interfere with the trans and bellhousing if you run the automatic.
Hopefully at least one TF guy will show some photos of his/her installation with a similar setup with a bit more advice on the swap. When I had my 57 Panel with the 327 I ran the stock 57 V8 bellhousing and stock 3 speed so clearance wasn't an issue.
My ongoing truck projects:
Old 02-21-2016, 04:43 PM   #3
Tod59
Thanks.
Old 02-21-2016, 05:44 PM   #4
Wrenchbender Ret
Like Mr Chev says, the biggest problem will be removeing the crossmember that the bell housing rides on & installing one in the rear part of the trans. I take it you are replaceing a 6 cyl. There are no problem with steering gear clearance. You will need a front engine mount kit & throttle kit. The swap is much easier with a manual trans.
Wrenchbender Ret is offline   Reply With Quote
Old 02-21-2016, 06:15 PM   #5
67 chevelle
67 chevelle's Avatar
you will require a crossmember , and the driveshaft shortened , probably a yoke also
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 02-21-2016, 07:03 PM   #6
Tod59
Thanks to all that responded!
Old 02-21-2016, 08:46 PM   #7
Apachemike
Apachemike's Avatar
It is the exact setup in my truck now 59 3100 350/700r4. Had original steering box and column but recently installed ps. Auto on the floor. PM me if you need anything or pics and I'll do what I can for you
Apachemike is offline   Reply With Quote
Old 02-21-2016, 09:45 PM   #8
mr48chev
mr48chev's Avatar
The simple way would be to get the tube crossembers that mount the engine and trans that every supplier seems to have and go that way.
Something like this but this isn't a suggestion to buy this one as they are available from a lot of sources http://www.speedwaymotors.com/Small-...Kit,81335.html
More here than you want to look at but it shows a variety of tubular trans mounts to pick from. http://www.speedwaymotors.com/Search...smission+mount
That would be the simple do it in a day way of installing the engine and trans. I've used a number of that style of engine crossmember over the years and they really simplify things on and installation.
Old 02-21-2016, 09:46 PM   #9
rrenner
rrenner's Avatar
I have that same setup. Plenty of clearance. Make the engine is back enough, depending on radiator chosen, and getting out the dist. can be a tight fit.
1958 Apache short bed
rrenner is offline   Reply With Quote
Old 02-21-2016, 10:00 PM   #10
Tod59
You guys are GREAT, thanks!
Old 02-21-2016, 10:42 PM   #11
JimDirt
Originally Posted by rrenner View Post
Attachment 1501617
Attachment 1501618
rrenner:
In that second pic , is the reason you have the tranny crossmember under the frame and the spacer (wood is temporary i assume) to the mount is because of the power brake booster ?? , and if so is the booster in the "normal" location ?? , and is this a issue with all under floor power boosters and the tube type engine/tranny mounts ??
JimDirt is offline   Reply With Quote
Old 02-22-2016, 08:25 PM   #12
rrenner
rrenner's Avatar
Jimdirt,
In this picture the cross member was temporarily clamped in for test fitting. The final position has it hanging in the frame rail. The booster is in the normal spot. Its a pretty close fit.
Old 02-22-2016, 08:51 PM   #13
OrrieG
OrrieG's Avatar
If you are just going to drive on the street for show and shines and occasional cruises you can get by removing the original bellhousing crossmember. But it is what ties the frame rails together at the rear spring shackles so any side loading on the shackle will move the frame right near the front body mounts. You can get a TH350 to fit above the cross member and below the cab floor. Makes getting to the front pan bolts interesting but not impossible, I have had mine off twice. You will also need to fabricate a two piece converter cover, it will not go in in one piece. Here are some photos of mine. I used a modified stock 74 truck tranny tailhousing mount for the transmission/transfer.
OrrieG is offline   Reply With Quote
Thread Tools
Display Modes
