Old 02-22-2016, 08:10 PM   #1
hey its me
Only luke warm heat.. even after I replaced stuff
First Chevy here.. First truck I might add too. The heat has never worked in my 81' sbc c10. I at least need defrost. I live in Seattle. I replaced the water pump, thermostat, coolant, flushed heater core yesterday, still no heat. The blower motor only blows cool air. The in/out heater core hoses are like warm to the touch even after the truck is warmed up. Ideas?
Thanks-Ian
hey its me is offline   Reply With Quote
Old 02-22-2016, 08:17 PM   #2
weider1717
Re: Only luke warm heat.. even after I replaced stuff
Thanks-Ian
It's your core try doing a reverse flush on it.
weider1717 is offline   Reply With Quote
Old 02-22-2016, 08:23 PM   #3
75C10
You have to move the heater hose from the water pump into the intake manifold. There is no pressure on the water pump the way you have it hooked up. The pressure is upstream of the thermostat. Move the temp sender thats in the intake and connect the heater hose at the same point. Put the temp sender into the cylinder head. Then it will all work fine.
75C10 is offline   Reply With Quote
Old 02-22-2016, 09:32 PM   #4
hey its me
Thanks guys. Ill find a 90 degree barbed elbow, move that hose, and plug the hole at the water pump. I'll reverse flow that SUMBICTH heater core too.
Old 02-22-2016, 11:16 PM   #5
75C10
Smile Re: Only luke warm heat.. even after I replaced stuff
If you have already flushed the heater core, doing it again would just waste anti freeze. Change the hoses and it will probably work fine.
Darwin
Old 02-23-2016, 12:52 AM   #6
rich weyand
rich weyand's Avatar
One more thing. There is usually a huge (~1") gap between the defroster Y tube and the heater box just above the hump. Use some metal tape (not "duck tape", but the actual tape HVAC guys use on ductwork) to seal that on three sides. The front side will be up against the firewall, so you can't get tape in there, but since it is up against the firewall, it's sort of sealed there anyway. Just look underneath the dash and you'll see what I mean about the gap.
Once you seal that, you will get the full flow of the blower up the defroster.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 02-23-2016, 01:21 AM   #7
barry1982
I had a 76 a few years ago that wouldn't throw any heat. Tried everything....
Finally ripped out the heater box and discovered a Bic lighter had somehow fallen inside one of the defroster vents and dropped into the heater box.. The lighter prevented the door in the heater box from sealing outside air. So basically the heater was throwing heat, but was mixing with cold air as well.
The truck had great heat after that.
barry1982 is offline   Reply With Quote
Old 02-23-2016, 09:33 PM   #8
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Cool Re: Only luke warm heat.. even after I replaced stuff
There's one more reason why smoking is bad for you and your truck! Lol
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 02-24-2016, 12:26 AM   #9
TrailerTrash
TrailerTrash's Avatar
kinda funny about the lighter lol
when i got my k10 two years ago it wouldnt change defroster/heater/vent/ect. so i discovered the line from the vacuum canister to the cab had come off. i hooked it back up and as soon as i started the truck the flap moved and a few bucks in change and some big gawdy costume jewlery necklace came tumbling out of the floor vent
TrailerTrash is offline   Reply With Quote
Old 02-24-2016, 11:23 AM   #10
rich weyand
Another problem is that low-compression SBCs generally run cold. I couldn't get decent heat out of mine until I replaced the runs-all-the-time mechanical fan with a thermostatically controlled electric fan, and, in the winter, put a cover over the center of the grill. Now I can get it up to operating temperature (needle straight up on the temp gauge, using a stock-resistance-curve temp sender) even when it is 10 below.
I just used a fender protector for my grill cover, with some squares of double-sticky tape on the radiator crossmember and a couple cable ties through the grill.
Rich Weyand
1978 K10 RCSB DD.
Old 02-25-2016, 12:40 AM   #11
barry1982
Up in the north country (northern Alberta) We cover our grills all winter. Some use "winter fronts" that snap on, and others use stiff cardboard slid right infront of the rad. Helps a lot with getting up to temp, and staying there.
Old 02-25-2016, 01:11 AM   #12
ChevyC102007
ChevyC102007's Avatar
Originally Posted by rich weyand View Post
Im thinking of getting that same bumper for my 1980 you have there.
But not to get sidetracked and highjack the thread...........after a few minutes the heater in my 1980 will run you out.....have to roll down the windows in the winter,
"When you were born, you cried and the world rejoiced.
Live your life so that when you die, the world cries and you rejoice."
[Cherokee saying]
2001 Dodge Ram Sport 1500 4x4. (old ride)
1987 GMC V1500 Sierra Classic ("new" ride)
ChevyC102007 is offline   Reply With Quote
Old 02-25-2016, 03:01 AM   #13
rich weyand
I like the bumper. It's dead-on identical to the original -- looks like it came out of the same tooling -- except for the punch-outs for the fog lamps. I did use a better switch and switch mounting panel than what came with it, but the relay and the wiring was OK IIRC. I need fog lamps around here to see the deer on the side of the road *before* they jump out into the headlights.
Rich Weyand
1978 K10 RCSB DD.
Old 02-25-2016, 06:38 PM   #14
hey its me
fixed. Heat works good. Moved the hose from the water pump to the intake manifold. Thank you all.
Old 02-25-2016, 06:42 PM   #15
75C10
Glad to hear it works well. Darwin
Thread Tools
Display Modes
