Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 02-25-2016, 02:02 PM   #1
DakotaKid
Wiring, Temp gauge wire, which one is the Hot lead? Changing use?
On the engine harness plug there are 2 wires for the temp sender. a Dark Green and a Light green from whati can see on the diagrams. I am going to eliminate these, but would liek to use the Power feed from this to run my electric choke. Is this possible? I have a set of aftermarket electrical gauges so i am not using the factory stuff and it would be easy to just change that wire over.
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
Old 02-25-2016, 02:32 PM   #2
ray_mcavoy
Re: Wiring, Temp gauge wire, which one is the Hot lead? Changing use?
Neither one of those wires is a power feed that would be suitable as-is for your electric choke.
The dark green wire operates the "HOT" light. And the light green wire operates the "COLD" light. Both of these wires lead back to their respective bulbs in the instrument cluster. And the temperature switch completes each circuit to ground to illuminate the bulbs.
To make use of one of those wires for your electric choke, you'd have to locate the other end under the dash and disconnect it from the instrument cluster connector. Then re-route it to a power feed that is switched via the ignition (adding an inline fuse would be a good idea too).
ray_mcavoy is offline   Reply With Quote
Old 02-25-2016, 02:36 PM   #3
DakotaKid
Thats exactly what i needed to know. Thank you for your reply. wasnt sure how that worked but that makes perfect sense.
Thread Tools
Display Modes
