Old 02-26-2016, 04:02 PM   #1
focusedontheprize
focusedontheprize's Avatar
3/4 Ton vs 1 Ton U Bolt Mounting
Hey,
I am picking up U Bolts for my 1 Ton and noticed that Chevy/GM went with a u-bolt reversal on the 3/4 ton.
Is there any particular reason for the differences? Thanks.
focusedontheprize is offline   Reply With Quote
Old 02-26-2016, 05:03 PM   #2
74CustomK20
74CustomK20's Avatar
Re: 3/4 Ton vs 1 Ton U Bolt Mounting
On the 1 tons (or in my C&C case) the top u bolt plates won't fit with the drums so close to the springs. Going downward with the u shaped bracket it'll work. All others have a gap so they can use Normal u bolt plates.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 02-26-2016, 06:30 PM   #3
chengny
chengny's Avatar
I think it might have more to do with the location of the lower shock mount bracket. On a 3/4 ton, the brackets are much closer to the perches than they are on a 1 ton. The u-bolt plates won't fit if they are installed under the axle on a 3/4 ton:
chengny is offline   Reply With Quote
Old 02-26-2016, 10:14 PM   #4
focusedontheprize
Thanks @74CustomK20 and @chengny. In the '65 I am running a Cab and Chassis 14FF so I have noticed how little clearance there is between the backing plates and the leaf springs.
Old 02-27-2016, 12:01 AM   #5
slotard
Speaking of U bolts, any suggestions on where to buy them? Mine's a C20.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 02-27-2016, 04:40 PM   #6
focusedontheprize
I picked mine up this morning at A1 Springs over in Oakland. Liked the guys and they ran $18.50 a piece.
Thread Tools
Display Modes
