03-01-2016, 08:38 PM | #1 |
1975 "BIG 10"??? VIN # Help!
Hey Guys.
I was under my truck the other day checking the pinion angle and noticed the large 8-pack leaves and 2 3/4" drums. One thing led to another and I found my SPID in the glove box. After searching the "F44" option I think I discovered this is a "BIG 10" (6200 GVWR listed on door plate). So it's a SWB, BIG 10, Silverado, 454 and TH400 from California. I attached the SPID which I just cleaned up and re-laminated. My VIN # CCZ1....is confusing me because the "1" should actually be a "4" if had the F44 option according to the LMC book. My SPID lists the F44 and VIN# matches the cab and title. Can someone clear this up for me? AKA is this a BIG 10 or not? PS the orange truck is not the truck in question. That was my 2nd love and this one is my 3rd love lol.
lowfastnloud Last edited by LOW 7FO; 03-01-2016 at 08:39 PM. Reason: clarify info |
03-01-2016, 10:25 PM | #2 |
Re: 1975 "BIG 10"??? VIN # Help!
What does the VIN on the dash say? Does it match the SPID?
03-01-2016, 10:31 PM | #3 |
03-01-2016, 10:55 PM | #4 |
It's a 1/2 ton with the f44 OPTION package so yes . But did yours have the Option of the decal big 10 or heavy 1/2 on it.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
03-01-2016, 11:19 PM | #5 | |
Posted via Mobile Device |
03-13-2016, 09:54 PM | #6 |
Excuse me but that is incorrect. 73-78 are on the door jam, 79-up are on the dash. 79-80 are in a slightly different position than 81-up. That is only really noticeable when you try to put a 81-up dash pad on a 79-80.
Thread Tools | |
Display Modes | |
