Old 03-11-2016, 08:51 PM   #1
weider1717
what you think about my compression readings?
Bought new plugs figured I would check the compression on my 87 only got half of them and my battery died and didn't charge and it's a new battery…anyway here they are. 87 350 5.7 69K miles.
BTW these were taken by my OTC compression test gauge supposed to be a nice unit so I assume readings are accurate.
cylinder #1- 172.5, 2nd test 174
cylinder #3- 175, 2nd test 175
cylinder #5- 175, 2nd test 179
cylinder #7- 180, 2nd test 180
Plug #7 the back one was a bit oily black wet other 3 were dry and looks pretty good. First test I have done been wanting to try out my test set any input on these readings? good? bad? so so? Also what should they be?
weider1717 is offline   Reply With Quote
Old 03-11-2016, 10:16 PM   #2
enaberif
Re: what you think about my compression readings?
What happened to 2,4,6, and 8? How did you do the test?
enaberif is offline   Reply With Quote
Old 03-11-2016, 10:50 PM   #3
weider1717
Battery died.
how i performed test:
I took the wire off the coil, unclipped the 2 fuel injectors. I did notice when I at first started to position the linkage back/open I created a bit of vacuum and I ended up not doing that but it looks to have slightly made a vacuum and the butterflies on the TBI setup aren't fully closed.
besides that removed the plugs and cranked it over 6 turns and took the reading then repeated.
I read most are like 120? mine is 180ish?? confused on this which is why I made this thread.
Old 03-11-2016, 11:05 PM   #4
68c10owner
68c10owner's Avatar
Originally Posted by weider1717 View Post
Battery died.
Was the engine hot or cold? That will make a difference. And you want the throttle at WOT when performing the test.
Anthony
68c10owner is offline   Reply With Quote
Old 03-12-2016, 01:00 AM   #5
weider1717
I started it up moved it to me shop ran probably 5min I'd say by time I got the last of the 4 out it was not hot by any means.
are you saying to stomp the throttle as I turn it over?
Old 03-12-2016, 01:20 AM   #6
68c10owner
68c10owner's Avatar
To do tje test correctly the throttle has to be fully open. Engine temp will effect readings.
Anthony
Old 03-12-2016, 10:31 AM   #7
MountainGoat1966
You must be close to sea level to get compression that high from a stock engine.
Where I live, we get around 120 or so due to the elevation. Go to Phoenix and you can get as high as 150.
"Off the grid and on the seven day weekend plan"
"One person cannot know everything, but between all of us, there isn't much we don't know."
MountainGoat1966 is offline   Reply With Quote
Old 03-12-2016, 11:15 AM   #8
weider1717
I am in upstate SC.
Old 03-12-2016, 12:27 PM   #9
lilpoindexter
lilpoindexter's Avatar
they are all fairly close to each other, so I think everything is all good
lilpoindexter is offline   Reply With Quote
Old 03-13-2016, 03:15 PM   #10
school boy
school boy's Avatar
The main thing is all the readings are in a close margin of each other. If the other 4 cylinders are in that range, I would be happy with it. You will prolly have to perform all the readings again when you test 2,4,6 and 8 since the engine was slightly warm on the first test.
.....__
..........._______ |__\__
..........|__(O)______(O)] ........................
school boy is offline   Reply With Quote
Thread Tools
Display Modes
