Old 03-12-2016, 10:04 AM   #1
Tumbleweed1C4
Tumbleweed1C4's Avatar
Why is my ac/heat ductwork so dang sloppy?
I repaired my flapper, bought and installed a vac canister, installed all new ductwork, and a new s-duct, and almost finished putting everything all together (with a new refurbished tach cluster ).
But I am not sure if I am missing something because the s-duct to floor vent/defrost box connection is looser than a goose. In fact, the whole thing is sloppy. The flapper box connection to the firewall box is screwed together, but not confidence inspiring tight. The s-duct is screwed on there, and then the floor/defrost box, and I feel as if I am relying on the bolt that goes through the firewall to hold the floor/defrost box to hold everything together, and it does a very poor job of it. I am starting to understand why the PO had a load of duct tape around everything. Not what I was hoping for. Here is a picture of the s-duct connection and everything together. It looks like it doesn't go in far enough to screw together as I can see the holes in the metal of the floor vent box and it is bottomed out. I flipped the s-duct around to make sure I had it on the right way and this ended up like it made more sense, but I could be wrong. What am I missing?
Sleep safe in your beds because rough men stand ready in the night to visit violence on those who would do you harm
72 K5 Blazer
72 K10 SWB (in pieces under slow construction!)
72 K20
Tumbleweed1C4 is offline   Reply With Quote
Old 03-12-2016, 10:10 AM   #2
Davidf
Re: Why is my ac/heat ductwork so dang sloppy?
The diverted box is supposed to be screwed to the S-duct.
Davidf is offline   Reply With Quote
Old 03-12-2016, 12:08 PM   #3
hdff
hdff's Avatar
Looks to me like it is
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 03-12-2016, 01:13 PM   #4
hdff
hdff's Avatar
"Wanda"
Old 03-12-2016, 01:35 PM   #5
F.A.A.benny
the s-duct should be screwed to the metal duct as well
F.A.A.benny is offline   Reply With Quote
Old 03-12-2016, 01:39 PM   #6
El Dorado Jim
I will take a look at mine and see if I can see any differences
El Dorado Jim is offline   Reply With Quote
Old 03-12-2016, 02:00 PM   #7
Tumbleweed1C4
I took it all apart and redoing it. I drilled new holes for s duct to metal housing, then discovered the top and bottom clear but screws front and back interfere with movement of defrost flapper. Put some of that double sided foam tape around metal duct to make a tighter fit. Will do same on firewall side and see if I can secure that joint better too.
72 K5 Blazer
72 K20
Old 03-12-2016, 03:59 PM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Why is my ac/heat ductwork so dang sloppy?
It's been a long time since I did mine but I'm thinking I redrilled the floor vent bolt hole and moved it closer to the passenger side of the truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-12-2016, 04:15 PM   #9
Tumbleweed1C4
I thought about that too Andy., but I think I got it pretty good now. Combination of several things. Put the foam tape to secure the s duct connections better, added a couple screws all the way around, and holes in heater core box were all wopped out. Put bigger screws in there, and everything came together pretty good. Installing new tach now and led dash lights and hopefully get her started and test heater/tach/led lighting today yet.
72 K5 Blazer
72 K20
Old 03-12-2016, 04:28 PM   #10
100%Chevy
Did you get the "S" duct from LMC?
If so,how does it fit?
And,did you buy new duct hose too?Is so,how well does it work?
I need to get these and wanting some comments on the quality before I buy if you don't mind.
Thanks,Mike.
100%Chevy is offline   Reply With Quote
Old 03-12-2016, 04:41 PM   #11
Tumbleweed1C4
I got both the s duct and the new hoses from the truck and car shop in Orange CA. The hoses are great. The cloth type just like original. They seem real good quality. A pain in the arse to put on, but good. The s duct is not great but ok. It only fit one way and both ends are bigger than the duct opening they attach to. I took up that space with the foam tape and put screws on each side and it came out pretty good. My old one was really busted up so I don't know if the original fit was any better or not. I read some bad reviews of truck and car shop in here but I just got two pretty good size orders of stuff from them for this stuff and a couple of clusters and they were real good. Called me with shipping and sent it out promptly. Good prices and they have a lot of little things that are hard to find. I will buy from them again.
72 K5 Blazer
72 K20
Old 03-12-2016, 04:47 PM   #12
100%Chevy
Thanks for your help!
Do you have a link for truck and car shop?
I've installed factory air in my 68 and need just these parts to finish it.
Mike.
Old 03-12-2016, 05:52 PM   #13
Tumbleweed1C4
http://truckandcarshop.com/
72 K5 Blazer
72 K20
Old 03-12-2016, 07:21 PM   #14
100%Chevy
Thank You sir!
Mike./
Old 03-12-2016, 08:25 PM   #15
Andy4639
Old member
Andy4639's Avatar
Glad you got it figured out.
I like the feeling!
Thread Tools
Display Modes
