03-12-2016, 08:53 PM | #1 |
Rewire Steering Wheel
I started rewiring my truck today, but ran into a road block. I got the steering wheel off, but how do I get the steering column apart so I can rewire the internals?
03-12-2016, 09:02 PM | #2 |
Re: Rewire Steering Wheel
Everything in the steering column is in the turn signal switch. You can get a new one from the vendors here or pick one up at NAPA.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
03-12-2016, 10:25 PM | #3 |
This info is for a tilt column - not sure if the non-tilts are similar, but depending on what you have it might help. I couldn't get my turn signal switch out of the housing easily, so I ended up taking the housing off first (brass punch), then removing the switch. I had to go deeper into the column anyway for my project. Removing the housing will also make it a little easier to feed the wires through.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
Thread Tools | |
Display Modes | |
