Old 03-23-2016, 12:53 PM   #1
cgster
73 Clamshell Motor Mounts
After reading multiple on top of multiple threads about which motor mounts/adapter to use for an LS swap on 67-72 trucks I have decided to go with a 73 clamshell mount and the dirty dingo sliding adapters.
Is this the correct 73 clamshell mount that they refer to?
http://www.ebay.com/itm/73-87-Chevro...1WEGv4&vxp=mtr
Also, is there anything else required besides the clamshell mounts and the DD sliders to mount the engine in place?
Thanks.
cgster is offline   Reply With Quote
Old 03-23-2016, 01:39 PM   #2
SaltyC20
SaltyC20's Avatar
Re: 73 Clamshell Motor Mounts
This is the engine side mount. The following dirty dingo slider will be used instead of this part. You will need to buy the frame side parts off the 73+.
http://www.ebay.com/itm/73-87-LS1-LS...pT7Pxu&vxp=mtr
1968 Chevy C20
SaltyC20 is offline   Reply With Quote
Old 03-23-2016, 01:40 PM   #3
Oldblue68chevy
The pieces in the link are the one that bolt to the motor. You do not need those with the DD sliders. You need the pieces that bolt to the frame mounts.
I used the same set up. Here is a pic of the frame mounts and the sliders on the motor.
Oldblue68chevy is offline   Reply With Quote
Old 03-23-2016, 02:01 PM   #4
cgster
SaltyC20 & Oldblue68chevy, thank you both for taking the time to answer and supply pictures. Much appreciated.
Old 03-23-2016, 06:57 PM   #5
UP GRADE
one set closer
UP GRADE's Avatar
I ordered these Friday received Monday them come unpainted and free shipping. http:/m.ebay.com/itm/Dirty-Dingo-Adjustable-Conversion-Engine-Mounts-LS1-Swap-88-98-2WD-GM-Truck-RAW-/221849177885?nav=SEARCH
UP GRADE is offline   Reply With Quote
Old 03-24-2016, 02:34 PM   #6
UP GRADE
one set closer
UP GRADE's Avatar
http://www.ebay.com/itm/Dirty-Dingo-...lVEqvB&vxp=mtr
Old 04-28-2016, 10:33 PM   #7
trukzguy
trukzguy's Avatar
Are you able to run the factory ac compressor in the factory position with these motor mounts?
Jay
Barrhead,Alberta,Canada
1967 GMC 400sb
Porterbuilt stage 2 front and rear suspension
http://67-72chevytrucks.com/vboard/s...d.php?t=419519
trukzguy is offline   Reply With Quote
Old 04-29-2016, 04:58 PM   #8
SaltyC20
SaltyC20's Avatar
In my 1969 C10 I have factory AC in the factory position with the DD slider and clam shell mounts. However, it is tight. I did a bit of clearancing on the frame and had to modify the compressor hose connections to get them to fit.
1968 Chevy C20
Thread Tools
Display Modes
