Old 03-25-2016, 11:53 AM   #1
65chevysub
65chevysub's Avatar
shifter pointer replacement
I need to replace the pointer on my 72 tilt column. Can someone give some info on how to do this, and where I can get just the pointer?
65chevysub is offline   Reply With Quote
Old 03-25-2016, 01:37 PM   #2
joeydurango
joeydurango's Avatar
Re: shifter pointer replacement
Super easy - just pull the two screws holding the indicator (P, R, N, D, so on) housing onto the column and remove. Tilt your wheel all the way down. Slide the new pointer in (assuming you have all the old pieces out), tilt the wheel back up, and re-install the indicator. Make sure the pointer corresponds with the actual gear you're in, adjust at the linkage to the transmission if necessary.
You can get the pointers at GMCPauls.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 03-25-2016, 01:52 PM   #3
65chevysub
65chevysub's Avatar
Thanks a bunch. I was expecting to have to take the steering wheel off.
Simple.
I appreciate the reply.. Thanks
Old 03-26-2016, 04:33 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Make sure the pointer is clipped into the back of the indicator so it stays up where it is supposed to be.
LockDoc
Leon
Thread Tools
Display Modes
