Old 03-25-2016, 11:27 PM   #1
Chevy3+3
How do '86 k30 front springs differ from the '88 V30's?
I am thinking about putting an add a leaf into my current front spring packs on my '88 V30 and I see alot listed for up to '86 & '87 being one part number and the add a leaf kits for the '88-91 V series are a different part number. I just wondered if anyone might know what the difference would be. The reason I ask is because there are fewer manufacturers for my '88 and Summit sells a Skyjacker add a leaf kit but lists it for useon vehicles up to '86.
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205
Chevy3+3 is offline   Reply With Quote
Old 03-26-2016, 01:12 AM   #2
chengny
chengny's Avatar
Re: How do '86 k30 front springs differ from the '88 V30's?
The parts dwgs for the 85/86 K30 and the 87-91 V30 appear to be identical:
chengny is offline   Reply With Quote
Old 03-26-2016, 07:19 AM   #3
wildwilly4x4
Im not 100% positive, but from what I remember the leaf spring mount bolts are a different size. For an add-a-leaf I don't think there would be any differences.
wildwilly4x4 is offline   Reply With Quote
Old 03-26-2016, 06:46 PM   #4
Chevy3+3
I might just need to call the company and see why the difference in part #'s then. I installed a set of Skyjacker 2.5" softride front lift springs over a year ago. Skyjacker guaranteed them to lift a big block truck 2" and a small block 2.5". They did lift my BB exactly 2" on day 1 but a year later I think they have settled about a 1/2" more. I thought an add-a-leaf may work to help the spring pack that's already there.
Old 03-27-2016, 06:28 PM   #5
redneckwheelman2
from what i found on ORD is that 88 and up they used metric bolts so the bushings are different, the springs are the same.
1987 v20 regular cab - work in progress swapped in a (1992 tbi 350 with vortec heads) old motor. currently has an 8.1l and 4l80 swap. flatbed bed 2 inch lift and 64 inch spring swap in the rear.
2002 chevy 2500hd extended long- blackbear tune. DD
redneckwheelman2 is offline   Reply With Quote
Old 03-27-2016, 08:54 PM   #6
MTCK
MTCK's Avatar
Have you thought about an ORD zero rate? It would keep from stiffening up your front springs, which you may or may not be going for.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 03-27-2016, 09:11 PM   #7
Chevy3+3
Yes I was considering that also. I was just concerned if the leaf spring pack kept getting weaker maybe it would be better to install a leaf spring instead. I do however love the way the my trucks front end rides at the moment and wouldn't want it much stiffer. I see that the front add-a-leaf kits will lift me up to 2". I really don't want that much more lift. I want to keep my height practical since this is more of a driver/tow rig rather than a offroad truck.
I did however install an NV4500 trans using the factory passenger side external slave cylinder so the additional height would give me more front driveline clearance. If I used an ORD zero rate kit I think I would have ample driveline clearance. If I still questioned it I could always just lower my axle bump stops a couple of inches as a safety precaution
Thread Tools
Display Modes
