Old 03-29-2016, 08:47 PM   #1
Towbiz
6 bolt wheels on 72 2 whl Dr
looking at purchasing a 72 2 whl Dr SWB , all numbers match but it has 4 wheel drums & 6 bolt wheels . To the best of my knowledge this went away in 70? It also has leaf rear suspension which must be rare but it's listed on options . Anyone know what year leafs were available in this model ? Maybe cab was swapped onto earlier frame but what are the chances that would have leaf springs too ?
Towbiz is offline   Reply With Quote
Old 03-29-2016, 09:27 PM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: 6 bolt wheels on 72 2 whl Dr
More likely it was a 4x4 before they gelded it.
Old 03-29-2016, 09:28 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
Does the cab vin match the frame vin?
Tyler
57taskforce is offline   Reply With Quote
Old 03-29-2016, 09:51 PM   #4
SS Tim
SS Tim's Avatar
Define "all numbers match".
SS Tim is offline   Reply With Quote
Old 03-29-2016, 10:52 PM   #5
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
You need to check the both frame vins against the title and cab. I had a guy try to sell me a 72 and he swore it was original. Once I started showing him how it was not, then the real story came out. I have "never" seen a 72 with 4 wheel drums from the factory. Never met anyone who reverse engineered a disk system to drums because they loved drums...I could be wrong, but something doesn't sound right. I would be very cautious about buying that truck.
You could get leafs or coils on both Chevy's and GMC's. Most Chevy's came with coils as most GMC's came with leafs. I did have a GMC Burb with coils and it was listed on the SPID.
70 was the last year for 6 bolt wheels on 2wd half ton trucks. If anyone knows anything different, please educate us.....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 03-29-2016, 10:53 PM   #6
Towbiz
Vin decodes to 2 wheel Dr SWB & it has low hump trans cover . It's quite a ways away so have not had opportunity to check # on frame .
Old 03-29-2016, 10:58 PM   #7
Towbiz
Old 03-29-2016, 11:04 PM   #8
Towbiz
If I recall on my 72 blazer 2 wheel partial vin # is stamped in frame near steering box ?
Old 03-29-2016, 11:11 PM   #9
71meangreenc10
The VIN on the frame only has half of the numbers stamped in it if you have never seen it. The first few digits are not stamped, but most of the middle to the end of the VIN is there. You should be able to match it up if it is legit.
Smitty
71 C30 Wrecker
Old 03-29-2016, 11:13 PM   #10
71meangreenc10
That is correct, the second VIN is on top of the driver side rail near the back of the cab. Could be closer to the seat location.
Smitty
71 C30 Wrecker
Old 03-30-2016, 02:44 PM   #11
Towbiz
Verified that serial # on frame matches so either this is one oddball truck or someone actually converted it from 5 stud disc to 6 stud drum ! Who would do that ??
Old 03-30-2016, 02:50 PM   #12
geezer#99
geezer#99's Avatar
You should give us a pic or a link to it.
Might be something obvious to see.
Old 03-30-2016, 03:04 PM   #13
SS Tim
SS Tim's Avatar
The frame VIN will be the last eight digits, year, plant and six for sequence.
Is this a Chevy or GMC? Oshawa (1) assembly or someplace else. Is the SPID optioned for overseas export?
Old 03-30-2016, 03:06 PM   #14
lolife99
67-72 parts collector,…
lolife99's Avatar
For some reason I read this as a 2wd blazer.
My mistake.
Please post pics when you get a chance,...
Keith
Convert to disc brakes.
Old 03-30-2016, 04:23 PM   #15
Towbiz
Chevy , built in Fremont & spid says " Calif vehicle reg." The spid / door tag & frame #,s match . To the best of my knowledge all blazer 2 wdr were coil spring & also changed in 71 to 5 stud / disc . I had a 72 2 wdr. that I did body off resto on .
Old 03-30-2016, 06:31 PM   #16
57taskforce
All about them K’s
I'm not up on 2wd parts interchange because I'm a 4x4 guy. Is it possible somebody with a pre 71 1/2 ton robbed the coveted 5 lug parts from this truck, then replaced them with the 6 lug parts from an older truck?
Tyler
Old 03-30-2016, 06:43 PM   #17
hugger6933
You know years ago these trucks were bought and sold in all shapes and states of disrepair. Most common being the motor and trans were missing, but someone could have robbed the 5 lug stuff off of it or possibly had two trucks and built his favorite and put the leftover parts on one to sell. I'm sure I'm not the only one that has had leftover stuff find its way onto a truck that ended up being a bargin for someone cause it was mostly leftover parts but still made a pretty decent truck. It is just things like 4 wheel drums could and quite possibly did end up on trucks made after 70 using this method
hugger6933 is offline   Reply With Quote
Old 03-30-2016, 07:46 PM   #18
Towbiz
Yes guys that about what I summed it up to as well , I didn't think the frame # was going to be a match at 1st . Thought someone swapped cab onto a pre 71 frame but that's not the case . This is a great site , tons of info .
Thread Tools
Display Modes
