09-27-2003, 04:32 AM | #1 |
air bag questions
ok i have 2 of the viair 450 compressors and two 5 gallon tanks. i was told i could run both tanks off one pressure switch with a relay, anyone have a diagram? i am also using the ride pro valves from air ride tech, 4 way system, what would be the best way to plumb everything,valves, tanks, compressors??? im going to start running airline tommorow.
09-27-2003, 11:10 AM | #2 |
This answer could go on forever, but look into a nice high dollar alternator one that actually puts out a lot of power at idle. The 100 amp chromies that you see all the time dont do squat at idle, they only put out that kind of power spinning fast.
Yes you will only need one switch in the tanks but they will need to be T'd together somehow. A couple of tips. Use check valves behind the solenoids so air pressure cant go back if the tank pressure goes lower than the bag pressure. use a dryer. use a constant duty solenoid...probably two for your application. use DOT approved line I have switched from teflon tape on the threads to liquid loc-tite on the pipe fittings and find it seals better. Buy a box of flexloom from Napa, they sell 50ft boxes much cheaper than those individual packs. Send the 12 volts from your compressor switch to the pressure switch on the tank, from there send it to the solenoid. I actually use three way switch for that, I can flip it one way and it runs til the switch turns it on and off, or I can flip the switch the other way and turn it on manually. |
09-27-2003, 12:17 PM | #3 |
Inline 69
this site has a couple of diagrams,,,,,,,,,,,,,pdf files
http://www.universalairsuspension.com/basicsystem.html hope this is what you need
09-27-2003, 10:40 PM | #4 |
thanks. that will help
09-27-2003, 10:58 PM | #5 |
Almost Satisfied
uh, yeah....buy stock springs and go with that instead! LOL
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
Thread Tools | |
Display Modes | |
