Old 04-19-2016, 10:10 AM   #1
72tutone
SBC .060 overheating problems. Suggestions please!
I have researched the site and have googled this topic but I need some real feedback.
I have been trying to break in my new motor. SBC .060 alum heads, edelbrock intake, holley 670cfm.
I'm running into serious overheating problems. I can get to about 5min or so breaking in the cam, and then i get heating problems and it boils out of the rad. I hate keeping to have to stop and start the motor like this. Granted when it does start we have the idle screw cranked up so its not really idling at all.
I have a stant 180 thermostat, stock 3 row rad and a 16" jeep fan with factory shroud. This thing pulls like 3000cfm.
I'm running a serp setup out of a 94 blazer with a new reverse rotation water pump.
I have the fan running all the time and the top hose is getting hot so the thermostat is opening. Just to be sure I boiled it and its opening as it should.
The lower hose isnt collapsing that I can see. I'm not sure what else it could be.
Could the rad be the problem? Ive already taken the water pump back and exchanged it out for a new one. I dont think the stat is the problem, or water pump.
Process of elimination would be the rad. Its a 16lb cap if that makes any difference.
We did have the bypass hose hooked up from the intake to the radiator. Thinking the hot water was running back from the bypass hose back to the rad, we plugged the hole in the intake and then ran the hose from the rad to the water pump. I'm not sure if any of this is necessary or not. I do have a factory AC but its not hooked up at all.
Could the rad be the culprit? Its the only other thing I can think of???
72tutone is offline   Reply With Quote
Old 04-19-2016, 11:08 AM   #2
hugger6933
Re: SBC .060 overheating problems. Suggestions please!
My first thought was backwards water pump but from my run ins with that the temp wouldn't jump up until you were like driving in traffic. I wouldn't run hot until you slowed down. Sounds like the rad is the culprit. I would check that next
hugger6933 is offline   Reply With Quote
Old 04-19-2016, 11:14 AM   #3
72tutone
Yep, Ive looked at the waterpump description to make sure its the correct rotation.
The donor serp setup is off an 94 s10 blazer. When looking at the setup it should be reverse rotation as the smooth portion of the belt drives the water pump pulley reverse as the crank turns clockwise so I should be ok.
Sanity check here please if I'm wrong.
But yes, the only other thing I can think of is rad. But all this was working fine with the clutch fan prior to me rebuilding it. So I dont know what in the world is happening here.
Old 04-19-2016, 11:20 AM   #4
Boog
laying low
Boog's Avatar
Bump up the timing. I bet it cools down. 😉
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-19-2016, 11:26 AM   #5
geezer#99
geezer#99's Avatar
I'd suspect your fan choice.
Clutch fan worked good!
Use it instead.
Easy test to see if it's air flow thru the rad.
Set up the biggest fan you can in front of the rad when you fire it up.
geezer#99 is online now   Reply With Quote
Old 04-19-2016, 11:30 AM   #6
72tutone
Geezer, this is the fan I'm running.
This thing apparently is to flow upwards of 3600cfm.
It definitely should cool it down. When the motor was running i was pulling in air through the rad with no problems.
Old 04-19-2016, 11:33 AM   #7
Coley
Coley's Avatar
Smile Re: SBC .060 overheating problems. Suggestions please!
A Jeep Fan...correct?
What jeep and what engine was this originally designed to cool?
V6, V8? or?....
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 04-19-2016, 11:34 AM   #8
72tutone
From I recall it was a v8 jeep.
Here is the thread that this all started from
http://67-72chevytrucks.com/vboard/s...d.php?t=254617
Old 04-19-2016, 12:45 PM   #9
WorkinLonghorn
WorkinLonghorn's Avatar
Not real experienced in heating issues but I once had a cavitation issue with air in the cooling system that the pump couldn't deal with. I think I forced water through the system with a garden hose until all the air was out then added the antifreeze while draining water from the drain cock.
Dumb question, but you are running 50/50 mix right?
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 04-19-2016, 01:09 PM   #10
cypressbog
Go Pack Go!
Did you have a shop remove the radiator tanks and rod it out?
cypressbog is offline   Reply With Quote
Old 04-19-2016, 01:12 PM   #11
trac209
Try running only water in the cooling system,a garden hose in an open radiator will keep the engine cool but you will get some water on ground in doing so.
trac209 is offline   Reply With Quote
Old 04-19-2016, 01:48 PM   #12
72tutone
Yes 50/50 mix.
Old 04-19-2016, 01:48 PM   #13
72tutone
I have not. My next move was to look at buying a new rad. I'm eliminating all possible issues at this point.
Old 04-19-2016, 01:49 PM   #14
72tutone
What would this eliminate? The mixture of coolant? I see what your saying Im just trying to understand what would be the result of doing this?
Old 04-19-2016, 02:02 PM   #15
geezer#99
geezer#99's Avatar
So your fan pulls big numbers but only in a 12 inch square area on your rad.
To be effective it needs to be mounted right against the rad, not in your shroud.
You're loosing a bunch of cooling area with that setup.
Old 04-19-2016, 02:27 PM   #16
72tutone
So your saying no shroud? I did have to move the fan back within the shroud toward the radiator some more due to clearance issue.
I have always thought when utilizing a pull feature you want the shroud? If I removed the shroud I still have an open area around the fan right? So wouldnt removing it not matter much
Old 04-19-2016, 02:29 PM   #17
cdowns
cdowns's Avatar
have you ever actually taken the temp with a known good thermometer or you just guessin
Old 04-19-2016, 02:36 PM   #18
72tutone
I have not, but when its puking out the radiator that doesn't sound good to me. And when my gauge is pegged in red; granted it is the factory gauge that means its running to hot for me. My thermo is 180. So I know its running 200+ for sure.
Old 04-19-2016, 03:12 PM   #19
hugger6933
Unless that fan is right up against the core it isn't doing much for you. Mount it close to the rad I mean close like you'd be to your girlfriend. Then cut some cardboard to place around the rest of the rad to act as a temp shroud to test this. With it back away from the rad like that your better off with a fan and clutch set up on there. If you go that way remember it has to turn backwards too, or you WILL overheat.
A fan/clutch of of a 88-95 truck or even an S-10 with the 4.3 would be worth trying. Jim
Old 04-19-2016, 03:16 PM   #20
72tutone
Hugger, the fan is moved back away from the front of the motor toward the rad. I think the way it is now I have about an 1/8 of an inch between the fan and the rad. I had to move it back within the shroud as the serp setup was hitting the fan in the shroud. If you look at the pic a few replies up, toward the bottom you will see how far it is back from the front of the shroud.
Is there anything else within the heads or gaskets that could be blocking anything? Edelbrock performer RPM intake, Jegs Alum cylinder heads and fel pro 1094 head gaskets. Torqued to spec. I thought the standard SBC 350 didnt have any issues unlike the 400 sbc that had the steam passages etc.
Thread Tools
Display Modes
