04-19-2016, 12:16 PM | #1 |
Better option than Dakota Digital?
Im wondering if there's a better option for me than dakota digital. I want gauges that read from the LS ecu and also add a wideband or scanner gauge like aeroforce offers. I guess the other option besides a one piece deal is doing individual autometer gauges but won't that interfere with what the ecu needs to read? thanks in advance for any help.
04-19-2016, 07:35 PM | #2 |
Re: Better option than Dakota Digital?
dakota digital is hard to beat. I have done 3 ls swaps and used dakota digital on all, also did another dd gauge setup in a chevelle with a 283.
04-19-2016, 10:43 PM | #3 |
I have the Dakota digital speedo box not hooked up yet. Directions aren't the best. Or maybe it's me. Calibration seems like it will be a pain also. I've never used a whole Dakota dash though..
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
04-19-2016, 11:34 PM | #4 |
Post Whore
Encased..on mine the only function the ecm needs is water temp,and that is used to run the fans, I added a temp sender on my passenger side head for my gauge and the ecm reads off the one on the drivers side head.all my gauges stand alone from the ecm.
Zach..i feel your pain on the dd directions for the speed box..I like to have never understood what to do..mine started out showing me doing 110 mph while idleing along in first gear..I finally got it and it works great now..I checked it with a gps and it stays right with it. |
04-20-2016, 12:13 AM | #5 |
meowMEOWmeowMEOW
RacePak
04-20-2016, 08:19 AM | #6 |
I understand they're nice and easy to install etc- it's just hard to stomach 900 big ones to have gauges that aren't the stock ones
04-20-2016, 10:54 AM | #7 | ||
http://www.dakotadigital.com/index.c...rod/prd752.htm http://www.dakotadigital.com/index.c...rod/prd785.htm I've installed 5 or 6 sets of these and they are hard to beat for price and functionality, just my .02. R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-20-2016, 11:04 AM | #8 | |
04-20-2016, 12:12 PM | #9 |
I'm planning on using a set of Speedhut gauges with a set of custom brackets I made to mount them to the back of the bezel. They have a series of gauges that read data from the CAN Bus on the ECU. Plus they let you custom design the gauges.
04-20-2016, 12:50 PM | #10 |
04-24-2016, 10:59 PM | #11 | |
The Older Generation
LockDoc
04-24-2016, 11:39 PM | #12 | |
Looks like a fix for my 78 Speedometer, so try one and tell me how it works!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
04-25-2016, 12:57 AM | #13 |
I used the gauges on my build and they work very well. Easy install, a couple wires and I was up and running. Speedometer does need some calibration but onced dialed everything works as described. Also looks great and alleviates the manual to electronic conversion mess.
04-25-2016, 01:04 AM | #14 |
Just a few wires,
fuel one wire to sender already there same with water, and oil, volts/light My LS harness has 1 wire kicked out that says speedometer, how is this callabrated to the new dash?
04-25-2016, 01:41 AM | #15 |
That wire labeled "speedometer" sends pulses to the gauges. The gauges take those pulses and converts the pulses overtime to return MPH. Meaning, your engine may send 7000'pulses for every 1 mile. Pulses per mile = MPH. All you need to do is measure 1 mile and hit start and stop at the end of the mile. You will see how many pulses after first run. Check speed after first run and adjust up or down till you are spot on. Validate with GPS on your phone.
Thread Tools | |
Display Modes | |
