04-25-2016, 06:55 PM | #1 |
Muncie 3 speed floor shifter
Hey guys, im doing an LS swap on my 72 swb and I would like to keep it as original looking as possible. With that being said I plan on pairing a 6.0L with a M22 muncie and would really like to use the factory floor shifter that these trucks came from the factory with. I know I will most likely have to do some fabrication work which is fine but does anyone know where I might be able to buy a reproduced shifter column?
1978 SWB cheyenne A/C, power steering/brakes, 305, Tach, Gauges 1972 SWB Custom 10, gauges, cammed LQ9, M22 |
04-25-2016, 06:58 PM | #2 |
Re: Muncie 3 speed floor shifter
I thought the M22 was a four speed?
04-25-2016, 07:19 PM | #3 |
m22 is 4 speed but the stock column im looking for came with the 3 speed transmission option with the granny gear
04-25-2016, 07:22 PM | #4 |
So you're looking for a manual column with no shift options attached correct?
04-25-2016, 07:38 PM | #5 |
Correct! I just need the stick itself.
04-25-2016, 10:10 PM | #6 |
Not sure if your lookin for a part of the steering columm or a floor shift stick like the trk four sps. have. I put a car 4 sp. in my 63 and used a trk four sp handle if that's what your lookin for let me know.
04-25-2016, 10:22 PM | #7 |
I'm looking for the shifter that came on the muncie SM465. I included a pic of the complete trans that includes the shifter. Not sure if they are reproduced anywhere. I apologize if I wasnt clear enough earlier.
04-25-2016, 10:45 PM | #8 |
that's what I thought ya wanted. just cut the hurst shifter off short and weld the trk shifter on.
04-27-2016, 12:22 AM | #9 |
thats a very cool solution. ingeniuos.
Thread Tools | |
Display Modes | |
