![]() Join Date: Oct 2014
Some parts needed for my "new to me" truck
The truck in question is a 72 Cheyenne C20 (just got it today!). The parts listed below are needed:
Glove box for a/c cab Tail light assemblies with wiring a/c and defrost ducts regular Cheyenne glove box door, maybe? (will trade for the "Cheyenne Super" one I have) Glove box latch with bracket and screws (non-locking one please) turn signal switch adapter for flat connector (column side) to "half moon" (body side) hood? Ignition switch nut
"Time off"? What is this "time off" you speak of?. Last edited by JayJayB; 04-25-2016 at 08:50 PM. Reason: Forgot to list something |
![]() Join Date: Jul 2001
Re: Some parts needed for my "new to me" truck
May be able to help with the ignition switch nut if the same from a '70. Think the '67s were different, not sure on that. Will get back to you.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
![]() Join Date: Jun 2005
I have a regular Cheyenne glove box door to trade for your Super door. What color do you need. I may have a NOS TS adapter- flat to horseshoe. LMK! Thanks, Dan
Sorry, the piece I have is the ignition spacer the switch mates to. Guess I can't help you much.
Color of door doesn't matter at this point to me.
Here's a pic of what I have:
"Time off"? What is this "time off" you speak of?. |
i have:
new glove box liner (for a/c) used glove box latch (non-locking) new curve to flat adapter new ignition bezel $72 shipped for all (includes ppal fee). thanks
Brian XNGH ECV Chapter 58 1972 Jimmy / Blazer Project 2wd 1974 Chevy Crew Cab Shorty |
I'll take the deal, but I don't get paid until tomorrow. Would you hold them until then?
no problem. i will pm you my paypal addy. just send payment when your ready. thanks!
I know it's expensive, but I wanted to see if anyone had a factory tachometer dash panel available that's useable, not necessarily mint condition and how much.
More parts needed for my truck:
Radiator core support radiator support brackets both doors Bed support bracket for left front corner Blazer tank support straps Blazer tank filler neck Jackshaft for steering Rear shock hardware for passenger side Shift linkage for column shift automatic
What size radiator support brackets, 2 - 3 row or for the big 4 row radiator? I know I have the upper brackets for a 4 row HD radiator with decent used cushions. Not sure I have the smaller 2 or 3 brackets. Also have some linkage for a column auto shift, not sure I have all of it. May have the passenger side shock bracket, will have to look and see what I have.
Found: the 4 row upper brackets, need cleaning, can bead blast, prime and paint for $22 lower passenger side shock bracket, coil rear end for $10 A/T linkage parts I have: trans to column rod for 2wd (4WD is longer, don't have) and the frame bracket with spring $22 for both pieces Will do $50 plus shipping, can do pics if needed.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks Last edited by Ironhorse; 05-01-2016 at 07:41 PM. Reason: Added info |
Pm sent
Thread Tools | |
Display Modes | |
