Old 04-28-2016, 09:57 AM   #1
kmswi
1976 gmc swap right gas tank to left side needs?
I am getting a box that is set up for a dr side tank and I need to replace the rt side tank anyway, can I use the mounts and straps on the dr side and just get a dr side tank?1976 gmc sierra grande long box 2wd ,I don't want dual tanks,
Tanks,
kmswi is offline   Reply With Quote
Old 04-28-2016, 12:17 PM   #2
daddyjeep
daddyjeep's Avatar
Re: 1976 gmc swap right gas tank to left side needs?
The tank and straps can go on either side of the truck. I'm not sure that is everything you are asking, but that is what i got.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 04-28-2016, 12:29 PM   #3
kmswi
So the frame brackets are the same also?The straps are rotted off and will be replaced.
Old 04-28-2016, 01:02 PM   #4
daddyjeep
daddyjeep's Avatar
http://www.lmctruck.com/icatalog/cc/865w/0051.jpg
Notice in the attached link, the only components that are right and left are the sending units.
04 1500 crew cab
Old 04-29-2016, 03:14 PM   #5
1774btcrew
1774btcrew's Avatar
The frame brackets will switch from side to side. Visually they are the same. The only difference is the rear bracket has one of the welded nuts in a different position from left to right. This isn't an issue as you can just nut it yourself if need be or if you have a welder just tack the nut on in the needed position.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Thread Tools
Display Modes
