Rough Country lift kit
Hey!
Anyone here who are/have used their lift kits? (67-91) I've been googling and searching on the forum but all threads are old. Most reviews I've read aren't very good, rough ride etc.. but maybe they do better stuff now? I rather wanna buy a Tuff country kit but there are no sellers for their kits here in Sweden :/ Im not gonna go mudding with the truck.
GMC C15 -68 project: http://67-72chevytrucks.com/vboard/s...d.php?t=526059 Front/back Porterbuilt dropmember, Accuair, LS1/4L60e Chevrolet C20 -72 C20 to K10/20 conversion, LS power. |
Re: Rough Country lift kit
There is a reason its called "rough" country. I'd look for a place that can get Tough Country, or do the 52" swap.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
20' Daredevil (Ret)
![]() Join Date: May 2003
Can you get Skyjacker Softrides in Sweden? As their name suggests, they are supposed to have a better ride than some of their competitors. I have 2 1/2" Softrides up front and they're not bad, and the quality is excellent.
![]() Join Date: Oct 2011
I think I read somewhere that after all these years of teeth chattering front springs , rough country decided to make something softer. Could be wrong though
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
I think the Rough Country springs aren't as bad as people exaggerate them to be. They are just pieces of steel that flex. Some flex better than others, but for decades springs made just like what Rough Country sells today were all you could get an none of the guys whined about the ride, just took it in stride as the way a tough 4wd truck rode when you lifted and put tires on big enough to hurt any good ride. The differences are minimal and yes some later companies with later designs have designs that are more flexible. I have been using Tuff Country EZ-ride springs for as long as they have been made. That's what I recommend all the time. But, last year I bought Rough Country front leafs for my truck and did an Add-A-leaf/2" block on the rear to retain hauling capacity and spend as little as possible. Tuff Country also sells HD front leafs. Has anyone run those to compare to Ez-Rides? Steak is better than hamburger but I still enjoy hamburgers
#6 | |
I've emailed a guy and ask how much they would take to import tuff country springs. They fly stuff from US every week. Thanks for the replies ya'll ![]()
Dang. I'll have to pay 2x more if I ship by air with all taxes and crap. I think I have to ship by boat (just 30% more) or go with Rough country springs... It sucks to live in Sweden when you like American pickups :/
I can really appreciate all it takes for you and others over there to keep old American iron going. It isn't always easy here. Most of what I see out of Sweden is also high on the attention to detail scale, which not just shows a level of love but also shows even greater effort in a place where nothing is easy with these things. One good thing. Once they are right they will go go and go.
K5Camper
![]() Join Date: Mar 2004
Like Special-k said, Rough country springs really get a bad rap but a lot of what you read on the web are clowns that want to brag about what they bought and talk bad about other brands they never even used. So do they ride like a set of skyjacker softrides or tuff country ez rides? No. This is coming from somebody that has used the same set of rough country springs on the front of 2 different K5's now. Is the ride objectionable? Not really. We are talking about a full size solid axle truck right?
Mine are stiff. But on the street it's firm, solid and not a lot of sway. On the trail, I air down to at least 15 psi in the tires. That makes a BIG difference in the ride on the rough stuff. So the springs really don't bother me much. I think getting better shocks would actually improve my ride over just getting softer springs. Are there better springs out there? Sure. Is it worth the extra cost to go better? Depends on the budget. Money no object I'd get a set of custom springs by ORD and get away from the mass produced stuff. But my reality is I don't have an unlimited budget and had to scrimp to save to get the rough countrys. They felt good enough to pull off my old 75 k5 and reuse on my 91. One of the few things that carried over. Keep in mind the biggest difference between the brands of springs is the actual spring rate. The soft springs have light spring rates so they should ride better. Problem is with soft springs is the load rating is less. Add a winch and second battery and that 4" lift might sag an inch. That soft rate will add to the sway going around corners on pavement. The higher spring rate keeps the load rating, will sag less with added weight of accessories and be more stable on road. It all really depends on what your plans are for your truck. Me, personally I'm ok with them. I'll save up for the ORD stuff later, but for now they work and I already have them.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
#10 | |
I'm probably gonna use it for towing and stuff like that so maybe the Rough country springs are the way to go if they are a bit stiffer and wont sag as much.
I put BDS springs on my3/4T truck, i like them ok they have slipper blocks between the ends of the springs i think it helps with the ride a little, and have tapered shims to help with drive line angle, they are plusher than the old Rancho springs i had. http://bds-suspension.com/
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
I am running rough country four inch lift(no blocks) and it rides pretty awesome for a lifted 40+ year old truck. Better than my buddies stock 2001 Ranger Edge.
#13 |
These are some early pics of the restoration , I really don't no why the rough country kit gets a bad rap, I personally think it rides smooth and looks elegant
.................._____ __________//___{\____ /__---____//____/__---/ .....(O). ..................(O). BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4 ![]() |
#14 |
My 70 Suburban, My 90 Suburban, My 72 Blazer all received 4" Rough Country suspension... If I decide to lift my 64 then that's the one I'll use...
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
#15 |
I think Im gonna go with Tuff country though, can't find a 6" lift from Rough. Could anyone of you guys go out and measure how wide the rear springs are at the eyes?
I'm converting my c20 to k20 but im not sure if the spring hangers have the same width between the 2x4 and 4x4.
#16 |
2 1/2". I bought some C/20 shackles for my 4wd when I couldn't find original replacements. I never used them but I think the only difference was the C/20s are a bit longer.
The 6" Ez-Rides will be a good choice. As lift goes up springs get stiffer and their design deals with that. I ran those all the way around on my old K/20 Highlander. It road really nicely. I like to run the hydraulic shocks. I feel nitro shocks were designed for Baja and I don't drive like that off road, slow and easy. Not concerned with cavitation or bottoming out on landings from being airborne.
#17 | |
#18 |
Your k20 could have either 52" or 56" rear springs. If you order one and have the other, it's not hard to move the rear preches.
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
#19 | |
#20 |
These trucks had 52"
#21 |
I had rough country 4" all spring lift on my '87 Jimmy. It rode firm both on and off the trail (more of a hunting fishing rig then mudder) . I even removed the sway bar, no need on road with the lift. I thought it was a great value for the money. I will tell you that my K5 with the 4" spring lift and ORD front shackles sat higher than a friends K5 on tuff countrys 6" all spring lift on the same set of 35" BFG muds.
Thread Tools | |
Display Modes | |
