Old 05-16-2016, 09:46 AM   #1
craigg1
Sending Unit Wire
I bought an under the bed gas tank (LMC truck) for my 68 c10. I have everything done except not sure how to hook up the wiring for the tank. The sending unit has a place to connect the wire (smaill stem sticking up), but it has no way of securing the wire (no nut or threaded area to hold on wire. Am I missing something? Thanks.
67 C10 SWB Chevy
craigg1 is offline   Reply With Quote
Old 05-16-2016, 09:56 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Sending Unit Wire
It is just a push on connector. You should be able to use the connector and a short piece of the wire from your other tank. Be sure and solder and heat shrink tube the solder joint.
LockDoc
Leon
Old 05-16-2016, 09:59 AM   #3
craigg1
LockDoc
Ok, thanks LockDoc.
67 C10 SWB Chevy
Old 05-16-2016, 10:32 AM   #4
craigg1
Any idea where to get the connector? I don't have the one from my old tank. Thanks.
67 C10 SWB Chevy
Old 05-16-2016, 06:31 PM   #5
LockDoc
LockDoc's Avatar
Here is a picture and a part number. Try Summit. Or maybe your local parts stores since you have a part number.... It looks like the new ones are a different style but they should still work.
LockDoc
Leon
Old 05-16-2016, 07:11 PM   #6
Shady Rascal
Shady Rascal's Avatar
the connector is an industry standard AC Delco PT197. I just bought one from Rockauto for about 4 bucks a couple of weeks ago.
https://www.rockauto.com/en/moreinfo.php?pk=251559
Shady Rascal is offline   Reply With Quote
Old 05-16-2016, 07:26 PM   #7
1968aj
will that also work for the temp sending unit?
1968aj is offline   Reply With Quote
Old 05-16-2016, 07:28 PM   #8
Shady Rascal
No sir. That's just for the fuel level sending unit.
Old 05-16-2016, 07:46 PM   #9
1968aj
ok thanks I am trying to hook up my temp gauge properly.
Old 05-16-2016, 08:24 PM   #10
Shady Rascal
Here you go brother. I can't find anyone, anywhere who offers one with the proper green wire color. If you can live with it being the wrong color wire, here is your solution for a sanitary repair for about four bucks.
http://www.repairconnector.com/produ...Connector.html
Old 05-16-2016, 08:37 PM   #11
1968aj
that will work just fine. thanks for the help
Old 04-26-2018, 11:59 PM   #12
hotwls13
Bringing back an old thread. I tried the acdelco pigtail on my sender. It is in a lmc rear mounted blazer tank. The post is too big for the pigtail to fit over. After messing with it for a while and trying to open it up I messed it up. Now gonna order the other pigtail from amazon. It is a 90 angle piece. Hopefully it fits a larger post. :/
hotwls13 is offline   Reply With Quote
Old 04-27-2018, 10:19 AM   #13
LockDoc
LockDoc's Avatar
The post on the Blazer tank doesn't have threads on it? If it is just a friction fit connector you should be able to find the correct pigtail for it if you know the year of the tank....
LockDoc
Leon
Old 04-27-2018, 10:29 AM   #14
hotwls13
LockDoc
Nope. It’s just a post with a bevel towards the top. About the size of a 3.5 headphone pin (actually looks a bit bigger than that). No idea what year tank. I got this truck 3 weeks ago and I think the tank was purchased from lmc by two owners ago and the swap was never finished. I tried contacting LMC about the tank kit but they never responded. :/
I ordered the other 90degree pigtail. Hope that one works. No time to go searching junk yards for an old connector.
Thread Tools
Display Modes
